Author Topic: Opinion on Gear Oil  (Read 673 times)
Vision
Opinion on Gear Oil
« on: July 04, 2014, 08:59:17 PM »
What do you think of this gear oil?
Royal Purple 01300 Max Gear 75W-90 High Performance Synthetic Automotive Gear Oil - 1 Quart Bottle
http://www.amazon.com/dp/B0007QGT34/ref=pe_385040_30332190_TE_M3T1_ST1_dp_3
Max-Gear is an ultra-tough automotive gear oil. It's designed to maximize power and provide unsurpassed protection to heavily loaded gears. It makes gears run smoother, quieter, cooler and longer without overhauls. Max-Gear outperforms other gear oils because it combines the highest quality synthetic oils with Royal Purple's proprietary Synerlec additive technology. Max-Gear is recommended for use in truck, motor home/RV and automotive front or rear differentials, manual transmissions, and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid. All viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary.
Vision
Re: Opinion on Gear Oil
« Reply #1 on: July 04, 2014, 10:43:53 PM »
I'm mostly concerned as it says it has a friction additive.
« Reply #2 on: July 04, 2014, 11:56:48 PM »
I don't use anything but BelRay gear saver.
