Did you miss your
activation email
Scooters - 50cc
Super 8
Safe to use piston stops ?
Topic: Safe to use piston stops ? (Read 677 times)
Chris0381
July 08, 2014, 02:45:30 PM »
I'll probably see about getting an impact wrench today, I read some people uses devices to stop the piston (commercial piston stops, a bolt with proper threads and rope etc) for on the road belt replacements; are these safe to use ? What would you recommend to take along to replace a belt out on the road ?
Would this tool work on the 2013 Super 8? It looks less damaging as I hate the thought of a chip or indentation on the top of the piston.
http://www.enviromoto.ecrater.com/p/5374715/naraku-variator-holder-tool-gy6-50
Actually this is the proper tool, I emailed Racingplanet and asked them if I can add it to my order that hasnt shipped yet.
http://www.racingplanetusa.com/variator-holder-blocking-tool-kymco-horizontal-p-256-1.html?cPath=2_21356_21372&sessID=4543f2535daada4a3c53e179cec01e87#.U7wLJ7Q0WSo
Last Edit: July 08, 2014, 03:18:44 PM by Chris0381
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
You never know do ya!
Close enough to get the idea!
Re: Safe to use piston stops ?
July 12, 2014, 07:38:58 AM »
You dont need any of that crap. You CAN simply hold the Var or clutch bell.
For on the roar repair w/ simple hand tools a short piece of 5/16" rope in the plug hole does the trick every time.
Back
