Author Topic: fuel gauge wiring  (Read 1202 times)
refrig
fuel gauge wiring
« on: July 09, 2014, 08:56:40 PM »
Got a people 2t scooter, someone disconnected the wires for fuel gauge. Need to know where they are connected on the gauge.
colors black,yellow, blue/white. thank you
zero
Re: fuel gauge wiring
« Reply #1 on: July 21, 2014, 06:10:48 PM »
Does not matter, the gauge  is just a resistor :)
« Reply #2 on: July 21, 2014, 06:17:37 PM »
Find a wiring diagram!!!
« Reply #3 on: July 21, 2014, 08:26:48 PM »
I get your question... The Black is the power, Blue/white is the feed power to the tank, and the yellow is the return to the gauge. I don't have a headset to see where they go on the gauge tho.
Check what I told you with a test light to confirm the power feed. Key on, and engine off. One will light up, and Duh... That is the power.
You can open the gauge housing to trace which do what from there. Two will go straight into the coil on the needle, and the last one (power ) will go to the gauge wire that is jumped into one of the needle coil wires.
I HOPE that helps.
zero
« Reply #4 on: July 22, 2014, 04:25:29 AM »
I wrong, I think you need wire on the fuel tank.
« Reply #5 on: July 22, 2014, 04:48:50 AM »
Wire is good my friend. That's how we are talking~ ;D
