Author Topic: Underglow lights  (Read 2491 times)
kimura
  • 2012 super 8 50cc 2t
Underglow lights
« on: July 13, 2014, 12:50:14 PM »
Thinking of adding underflow lights to my scoot, something like this.
http://www.ledunderbody.com/4pc-classic-single-color-motorcycle-lighting-kit-1.aspx
anyone have experience with this? I'm going to be having my scoot mechanic install them. I was wondering if it will be any kind of strain on the electrical system.
kimura
Re: Underglow lights
« Reply #1 on: July 13, 2014, 01:14:16 PM »
heh, I need to find out if they are even legal in NY,  anyone know?
kimura
« Reply #2 on: July 13, 2014, 05:44:29 PM »
I figure white shouldn't be that bad so i ordered these
http://www.joeflorida.com/54-led-single-color-super-bright-motorcycle-road-coverage-accent-light-kit/
with a switch, if I see cops ill just switch them off.
« Reply #3 on: July 13, 2014, 06:06:16 PM »
If I'm not mistaken any added lights like that are illegal in every state. That being said I have them on my zuma and have never been messed with. I only turn then on once and a while.
kimura
« Reply #4 on: July 13, 2014, 06:28:01 PM »
which ones do you have and what colour?  got any pics?
« Reply #5 on: July 13, 2014, 06:36:17 PM »
It's just a 15" strip I got in superbrightleds.com on sale for like $9. No pics tho, It's red and looks alright
Chris0381
« Reply #6 on: July 13, 2014, 08:04:50 PM »
Walmat is $18 a pair. White in front, red in back, no blue and I'm not sure about under the bike.
http://traffic.findlaw.com/traffic-tickets/neon-underglow-lighting-laws.html
Your safest bet is yellow or amber color. Green or blue cant be used here in Connecticut. If light can be seen from front it has to be whit, yellow, or amber. From rear it has to be red, yellow , or amber. The under light will be seen from rear and front so go with yellow or amber maybe.
« Last Edit: July 13, 2014, 08:24:54 PM by Chris0381 »
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
AVGuy
« Reply #7 on: July 14, 2014, 02:50:21 AM »
I called the state police post closest to me and asked. They were very helpful. In Indiana, you can only use white or amber and the strips have to be mounted where they aren't directly visible.
Grand Vista 250
"Big Scoot"
« Reply #8 on: July 14, 2014, 04:56:45 AM »
They are on their way over to verify yours right now. I never knew anyone that voluntarily called the cops. Life is full of firsts...
joebro
« Reply #9 on: July 14, 2014, 01:39:54 PM »
I would check into it. I know around here its a ticket if we get caught with them under our bike, scoots, or cars.
You only live once but if you live right once is all you need.
kimura
« Reply #10 on: July 15, 2014, 12:17:32 AM »
do you guys think it would be much of a strain on the scoot's electrical system?
AMAC1680
    • SEGS4VETS
« Reply #11 on: July 15, 2014, 12:36:05 AM »
Got that right bubba !
Be Big,
AMAC
www.SEGS4VETS.org
2017 Lance Cali Classic 200i
2013 SYM RV200
2013 Kymco Downtown 300
2010 Lance Cali Classic-sold
1973 VW Dune Buggy
1974 VW Meyers Manx
« Reply #12 on: July 15, 2014, 01:39:17 AM »
you should be ok if you have a on and off switch and a inline fuse.
« Reply #13 on: July 15, 2014, 01:46:53 AM »
In michigan we can only use white .colors distract drives.
« Reply #14 on: July 15, 2014, 01:52:35 AM »
What I would do is replace all the running lights w/ LED's. Same for the blinkers but you will also need an electronic flasher module. Everything is plug, and play, and well under 20 bucks.
Reason is the OEM stator puts out 35 watts of power continuous, and 60 peak. Your headlight alone draws 35 watts.
Lots of fellas have installed them (light strips) w/ no issue but I don't like the idea of stressing electrical parts.
All the direct replacement bulbs are on Ebay, along w/ the flasher. It would take you less than 2 hours to install everything for a first time doing it.
« Last Edit: July 15, 2014, 01:54:15 AM by zombie »
