Author Topic: Cyclic vibration  (Read 1338 times)
motorandy
Cyclic vibration
« on: July 22, 2014, 08:07:21 PM »
Hello,
  Picked up a 2004 P150 about 3 weeks ago.  I noticed a cyclic vibration that occurs between 45 and 55 MPH (indicated).  The tires appear okay (some cracking).  I suspect stuck rollers or a bad belt.  What I would like to know from the members is, do other P150 do the same thing?
Thanks!
Calothrix
Re: Cyclic vibration
« Reply #1 on: July 24, 2014, 02:53:56 AM »
Welcome, my 2005 P150 does not have that problem.
motorandy
« Reply #2 on: July 28, 2014, 10:18:54 PM »
Thanks for the response.  I guess my next move is to remove the belt cover and check the rollers and belt.
Best,
MotoRandy
Calothrix
« Reply #3 on: July 29, 2014, 02:29:01 AM »
The OEM rollers in my 2005 People 150 are 18 mm x 14 mm x 15 g.  I replaced my OEM rollers with 13 g sliders and the top and bottom end is very similar to the rollers.  If anything, I might have gained a little on the bottom end and lost a little on the top end but it is hard to tell.  Acceleration is very smooth.   I have  put several thousand km on the sliders now and I have been very happy with them.....no problems to date.  If you need to replace the rollers, you might consider going with the Dr. Pulley sliders.
motorandy
« Reply #4 on: August 16, 2014, 04:52:41 AM »
Well, I removed the belt cover and found the rollers had flat spots in them  I bought Dr Pulley sliders (13 g) and the small variator plastic pieces (3) for the cover.  I then took it for a ride to see what change had occurred in the vibration.  It's gone!  Nice and smooth up and down the entire powerband.
Thanks for everyone's input.  It helped.
Best,
MotoRandy
