Did you miss your
activation email
Scooters - 125 to 300
Grandvista 250
Add LED lights
Topic: Add LED lights (Read 1370 times)
GBBBiker
Jr. Member
Add LED lights
July 25, 2014, 03:25:42 PM »
I want to add led lights to my Grandvista. A tail light/ brake light combo to the back of the back seat rest. LED strips to the side and back. I sthere an easy way to access the wiring without removing body panels? Any help appricated.
Carter Merz
Re: Add LED lights
July 25, 2014, 03:44:56 PM »
Just with the seat bucket out you should be able to access the tail light connector.
GBBBiker
Jr. Member
Re: Add LED lights
July 27, 2014, 12:38:55 AM »
;)Thanks for the tip.
GBBBiker
Jr. Member
Re: Add LED lights
Reply #3 on:
July 27, 2014, 08:08:41 PM »
I looked at the seat bucket and could not figure how to remove it.
Carter Merz
Re: Add LED lights
Reply #4 on:
July 27, 2014, 09:17:53 PM »
4 10mm bolts under the carpet. Should pull right out after that.
Urbestfriend
Sr. Member
Re: Add LED lights
Reply #5 on:
July 28, 2014, 12:08:08 PM »
Probably will have to remove battery and access plate behind it to access light harness.
Back
