Author Topic: Where to find Parts  (Read 1284 times)
drag
Where to find Parts
« on: July 26, 2014, 06:48:25 PM »
So I got a kymco from a guy and long story short. I have a pair of rocker arms and a camshaft that may or may not fit either the KN125 engine (agility 125) or a cheap chinese scooter engine. Is there anyway to tell what a kymco cam shaft and rocker arms look like?  If not im just gonna be safe and buy both. Anyone know where I can buy OEM agility 125 rocker arms and camshaft? I looked everywhere online to now luck.
Re: Where to find Parts
« Reply #1 on: July 26, 2014, 07:12:55 PM »
Any gy6 rockers and cam will fit because that engine is gy6.
drag
« Reply #2 on: July 26, 2014, 10:00:04 PM »
Yea but it doesn't. There's About a quarter inch or less of clearance. I will post pictures soon.
drag
« Reply #3 on: July 26, 2014, 10:57:39 PM »
Ok here we are.
Here you can see the cam sits nicely in the rocker arms
http://i78.photobucket.com/albums/j101/dragon3650/PhotoJul2660140PM.jpg
Here you can see the intake valve is slightly longer than the exhaust valve
http://i78.photobucket.com/albums/j101/dragon3650/PhotoJul2660105PM.jpg
Here you can see it doesnt sit properly on the head
http://i78.photobucket.com/albums/j101/dragon3650/PhotoJul2660218PMHDR-1.jpg
I cant tighten it down or else I will be compressing the bearings themselves on the came which I know isnt smart.
« Reply #4 on: July 26, 2014, 11:34:12 PM »
I don't know what to tell you, I've used gy6 stuff in there before. Are the rocker arms gy6 or kymco?
drag
« Reply #5 on: July 26, 2014, 11:49:32 PM »
Thats the thing I got a kymco body and 2 half built engines. so I honestly dont know. Theres no markings that say kymco. To me they look like regular gy6 rocker arms. But i cant tell because I never seen a kymco engine opened up until now. Even if I wanted to buy new rocker arms and a cam shaft just to be safe I cant find anywhere online that sells them.
One of the engines was a GY6 150cc and the other was the kymco engine
Follow up:
I took off the valves and everything sat correctly which leads me to assume that the rocker arms are not big enough. And went I went to measure the valve length it came it at a whooping 81 mm. (this is from the kymco head) So I either need some small valves or some OEM rocker arms right?
« Last Edit: July 27, 2014, 12:42:55 AM by drag »
