Have had a couple requests for an owner report on my Forza.
About 200 miles on the new scoot - so, keep that in mind.
And that I am coming from a 163cc, Like200i.
Pros:
The longer wheelbase, added weight, larger wheels and wider tires make for a much smoother ride than the LIKE. (some Forza owners complain about the scoot's harsh ride - I greatly suspect they are coming straight from a Buick - not from a smaller scooter. This Honda is much smoother riding than the LIKE!)
I am getting pretty close to the gas mileage of the LIKE, and have a 3 gal. tank.
With the tank, battery and engine set very low in the scoot I find the scoot to be easy to balance in spite of the extra 200 lbs. over the LIKE. I can almost stop with my feet up on this scoot - something I could not do on the LIKE.
The hand grips/handle bar is several inches above my knees (You can rotate the handlebar up, and then rotate the brake levers to suit - in 10 mins with hand tools) The handgrips on my LIKE are level with my knees.
I like the 'combined braking' in the left grip lever. The brakes are powerful!...but so are those on my LIKE!
I like the parking brake.
There is room for 2 full face, modular helmets under the seat....I've tried it.
I like the easy to read dash with seperate fuel, temp, speedo and tach gauges, multi-function read-out dial; the oil, park brake, oil change, high beam, etc. lights.......and that the turn signal flash indicators on the dash are
in my line of vision with my full face helmet on. My chin bar completely blocks my dash on my LIKE, requiring a head movement to see how fast I'm going and that I've forgotten to cancel my turn signals -
not a good thing in traffic!
I like that both headlights are lit even on low beams - so you don't look like your riding around with one eye out. The lighting of the road is very good.
Turn signals are not on add-on stalks.
Fit and finish and paint seem perfect so far.
One front storage locker is
very deep, has a outlet in it, and is operated by a lock-out switch, key activated from the ignition. Switches like this also open the seat and the gas flap. The other front locker is finger opened & smaller.
Ignition key hole has a cover.
The coolant level is viewed by a window in the lower body panel.
Coolant top-off, spark plug and valves access seem to be fairly mechanic friendly (Honda uses tiny shims to set the valve lash)
There is already a @200 page clear & comprehensive service manual on my desk ...shipped for $36.
I've located at least two good OEM parts on-line suppliers.
Parts prices seem very good.
The owners manual clearly states that owner servicing IS permitted! (just don't screw it up!)
I like the spin-on oil filter. My first oil change at 170 miles cost me $30 ($15 for the filter and $15 for 1.5 Qts of HP4M oil....which is used for the gear oil as well) Oil changes are at 8,000 miles, valves at 16,000 !
Yes, well, I'll be doing them much more often than that.
I will likely extend it beyond the 600 mile intervals I do on my LIKE, but not much.
Verdict is still out on the Dunlops as I corner like a senior on a scooter and I haven't ridden in a down-pour, yet.
I like that I got out the door for @$750 less than a lot of markets.
There are 4 Honda scooter dealers within an hour of me.
Cons:Ther silly 28" seat height is taking some time to get used to(my LIKE is built up to about 34")
The dumb back rest is gonna go to the floor of the seat ulpholsterer as soon as I can afford it. I'll have him raise my seat as well. Japan is already selling custom seats for the Forza - I may look into that.
I very much miss the huge flat floor of the LIKE. I have to mount this scoot like a bike - which makes the idea of a top case questionable. I'd be kicking the snot out of it.
Mirrors are too short. Extenders are on my desk.
Honda sells a taller wind screen - $125. But I'm not a fan of any wind screen.
Problems so far:
I thought the gas gauge was broken....but it just took awhile before it started showing that I'd used any fuel! It
is easier to fuel my LIKE.
Like most new scooter owners - I am very happy with my purchase of the 2014 Honda Forza / NSS300.
