Did you miss your
activation email
Scooters - 50cc
Super 8
New exhaust
Topic: New exhaust (Read 1180 times)
crazy8
Newbie
New exhaust
July 29, 2014, 04:50:57 PM »
I just installed a Tecnigas Next-R on my 2T with smooth boss and 82 jet. I easily did 42 MPH - is that about right for my mods?
gnvernon
Jr. Member
2012 Kymco Super8 2T
Re: New exhaust
July 29, 2014, 06:02:10 PM »
upjet and bore out the airbox for a little extra speed. That exhaust is nowhere near its' limit with an 82 jet. You could get 42 MPH with those same derestrictions and a modified stock exhaust.
crazy8
Newbie
Re: New exhaust
July 29, 2014, 07:36:34 PM »
Thanks. Help me understand how to bore out the air box. I pulled the air box and didn't see a restriction. The was a tube from the inlet to the middle of the filter, but I didn't see a restriction beyond that. btw, my Super 8 is a 2013.
Chris0381
Re: New exhaust
Reply #3 on:
July 30, 2014, 02:27:06 AM »
I'd upjet to a #86 and have a #90 and #92 on stanby should you want to experiment with them. Boring the box is a bit more complicated because if you overdo it you'll need to patch it up. Try the upjet first then consider new rollers and maybe even a contra (torque spring). Just from what I have beed reading through and not personal know how.
Also consider exposing the airscrew for more tuning capabilities.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
gnvernon
Jr. Member
Re: New exhaust
Reply #4 on:
July 31, 2014, 01:53:19 PM »
how will you know if youve opened up your airbox too much?
Chris0381
Re: New exhaust
Reply #5 on:
August 01, 2014, 02:18:14 AM »
Quote from: gnvernon on July 31, 2014, 01:53:19 PM
I guess your plug chops would come out lean or the engine overheats. Ive read a few posts where peple have had to patch it back up or get a new airbox. I'd like to know myself because I'd like to open my box and upjet more also.
Smooth Boss
Polini Variator
#95 Main Jet
Back
