Author Topic: Agility 50  (Read 2601 times)
Laraway
« on: October 03, 2009, 02:42:29 PM »
I have a 2007 Agility 50.
I purchased it not running, I have discovered that it has only 15 pounds of compression.
I think this job, rings and piston is out of my league, What would be a fair price to expect to pay at a shop?
Is any reader in the Tucson Az. area able to do the job?
Jim
laraway@comcast.net
Re: Agility 50
« Reply #1 on: October 03, 2009, 08:31:02 PM »
for the price of a re-bore, piston/ring kit, gasket set, you can get an aftermarket cylinder kit complete. If the compression is that low I would carefully inspect the lower end for wear. It dosen't sound like you are to "into" tearing it down yourself, so I would think $400.00-$600.00 US would cover a rebuild at a good shop. With all the correct parts a re-build should take 3-4 hours. There may be a shop local to you that will take a core on your engine, and supply a rebuilt to you. Then again if ALL else is good it should only take about an hour or so to change the piston/rings, about $50.00. Is yours 2stroke or 4?
Laraway
Re: Agility 50
« Reply #2 on: October 03, 2009, 09:38:13 PM »
fOUR
benhogan73
Re: Agility 50
« Reply #3 on: October 15, 2009, 06:32:38 PM »
The 400 to 600 estimate may be high.  I should think that would cover all repairs, including any carb cleaning and adjustment.  If you pay that much, you should get back a very smooth running bike.
Tim
Re: Agility 50
« Reply #4 on: October 15, 2009, 10:24:42 PM »
That is exactly my thinking. I run my own business (fiberglass/ paint) and will always give a high estimate to cover any incidentals. If the shop is honest, and good... the repair can come in around 1/3 - 1/2 less. Hope it works out for you Laraway. If you would please post back w/ your results, you may help another in your situation.
