Did you miss your
activation email
Scooters - 50cc
zx50
backfiring?
Topic: backfiring? (Read 868 times)
zx50 4life
Newbie
backfiring?
July 30, 2014, 05:24:29 PM »
New big bore and crank installed, when trying to start a loud pop comes from exhaust. 90cc kit and stroker crank from ebay, 28mm and 24mm oko carb v8 exhaust.
zx50 4life
Newbie
Re: backfiring?
August 03, 2014, 12:58:55 AM »
Ok, I think it's the timing. I took the key off the crank and readjusted the flywheel. It started then died out. What is the correct degree should the flywheel be set to at tdc
Carter Merz
Re: backfiring?
August 03, 2014, 05:44:36 AM »
I think you might be looking at it wrong, these flywheels aren't adjustable...... Factory timing should run the engine even with a cylinder and crank. You need to check for air leaks.
Back
