Author Topic: How to remove the 300i handle bar cover?  (Read 1094 times)
castle
« on: July 31, 2014, 09:45:03 AM »
hi,
i want to wire a voltmeter from the handle bar. but i couldn't remove the handle cover after taking out the 4 screws under it. did i miss out somethings?
padmovie
    • my other lady
Re: How to remove the 300i handle bar cover?
« Reply #1 on: July 31, 2014, 11:15:11 AM »
No, you don't miss anything, the top cover is hard to take, there are only plastic clips after screws removal,
just more force ... 8)
« Reply #2 on: July 31, 2014, 12:06:50 PM »
did you see the two bolts one on each side ,.  and remove the rear view mirrors
castle
« Reply #3 on: July 31, 2014, 04:06:12 PM »
ok. thanks.
didnt dare to exert too much force. afraid i might break something. will try again.  :)
Adept
  • Empaticus Maximus
« Reply #4 on: July 31, 2014, 06:42:48 PM »
It is not a rigid plastic. You can use a little force. As I remember (Heated Grip assembly) there are little clips under the plastic...
I have a barely used (200km)14gr Dr Pulley rollers to SELL!! Send a PM if you interested in...
