Author Topic: Oil & Smoke  (Read 1076 times)
19krevs
  • Cash Rules Everything Around Me
Oil & Smoke
« on: August 01, 2014, 11:24:52 AM »
Just about every video I see of someones 2 stroke scoot (ones that are running great) they have smoke pouring out of their exhaust, I know some people would prefer not to but I like the idea of it smoking up a lot. My scoot is pretty good, only smokes a tiny bit on start up/low revs. What causes this, type of oil used? (fully synthetic etc) carburetor settings? higher oil to fuel ratio?
Kymco YUP 50
-Malossi Sport 70cc
-Arreche 21mm Carb
-Tecnigas Next R
Re: Oil & Smoke
« Reply #1 on: August 01, 2014, 04:48:54 PM »
Smoking two stroke comes from premixing. With oil injection it's getting very little 2t oil at idle burns cleaner. Synthetic 2t oil will usually smoke less. You won't get that super smoke without going all out with tuning. Premix will always be burning whatever ratio you mix to (i.e. 32:1) while injection will be as low as 100:1 at idle.
19krevs
Re: Oil & Smoke
« Reply #2 on: August 02, 2014, 04:35:52 AM »
Cheers for the insight, I run 35:1 premix with semi-synthetic I thought that was a high-ish oil mixture compared to some others and always wondered why it doesn't smoke much.
Kymco YUP 50
-Malossi Sport 70cc
-Arreche 21mm Carb
-Tecnigas Next R
