Author Topic: Big bore kits  (Read 3191 times)
Stellagod
Big bore kits
« on: August 03, 2014, 01:50:05 PM »
Hi, can anyone please let me know what sort of performance increase an 80cc or 100cc big bore kit will provide to a derestricted Agility RS 50? The scooter is stock apart from smooth roller and derestricted ecu. It does 36-37 mph at the mo'
Cheers
tortoise
Re: Big bore kits
« Reply #1 on: August 03, 2014, 04:04:21 PM »
Potential downside is heavier piston = unbalanced crankshaft assembly = enhanced odds of bearing failure.
Re: Big bore kits
« Reply #2 on: August 05, 2014, 03:12:12 AM »
Better off with bigger scoot.bbkkare a wast of money .I have seen to many scoots blow up or bend cranks.
Chris0381
Re: Big bore kits
« Reply #3 on: August 05, 2014, 02:51:32 PM »
I second the bigger bike, if you a good bike mechanic and have the shop to balance everything then a BBK may be good but for us tinkerers, we could do more harm than good. I have read people seizing their motors at 200 miles with a BBK not to mention wear and tear on other crucial components like reed valves and needing carb and exhaust tuning also.
Im no expert but I do a lot of searching other forums etc.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
Stellagod
Re: Big bore kits
« Reply #4 on: August 06, 2014, 08:29:16 PM »
Hi again, Thanks for the feedback. I take it there is no good reason to fit a big bore kit then? Does anyone on the forum have anything positive to say about them?
Cheers
Chris0381
Re: Big bore kits
« Reply #5 on: August 07, 2014, 11:10:17 AM »
Cheers
Yes, they add HP and enhance the performance but need to be done right.
Smooth Boss
Polini Variator
#95 Main Jet
JJJoseph
  • Kymco Sento
Re: Big bore kits
« Reply #6 on: September 04, 2014, 12:30:52 AM »
No need to change the crankshaft, it's the same crank used in 50cc and 100cc models.  Any GY6 cylinder & piston kit works fine.  There's not that much difference from one brand to another. With the stock head, the compression is on the high side and it's stiff to start.  A new head matched to the BBK might be a better choice.  I use the stock head and hog it out with a Dremel to lower the compression slightly, plus carb rejetting.  All the above just gets you faster acceleration (a LOT faster), but no extra speed.  Adding a performance cam and gears in the rear-end will give you more speed.
Suggestion: when you order your BBK, ask if replacement oversize head gaskets are available. They're specially-formed steel gaskets.  If the supplier doesn't offer them, don't buy the kit.  You'll need a gasket sooner or later, and you don't want to have to buy a complete BBK just to get a head gasket.
