Author Topic: Super 8 2t top speed  (Read 5117 times)
aaron8
« on: August 05, 2014, 12:28:38 AM »
Alright guys I'm looking for someone that sells final drive gears for the S8 2t
When we derestrict our scooters we are getting them to go 40-42 (on the speedo)
Removing exhaust washer and all emissions
Removing intake washer
Installing drive boss
And #90 jet
Now we have installed a few 70cc kits and it gives it a lot more low end grunt, but the top speed stays the same maybe goes up to 45-47
So is anyone making final drive gears for these bikes?
Chris0381
Re: Super 8 2t top speed
« Reply #1 on: August 05, 2014, 11:40:17 AM »
What are you doing exactly that allows a 90 main jet to be used without it running too rich? Are you opening up the air screw or doing something to get more air in the carb ?
I'm at a fairly easy 40 MPH (only the flats) with blind pipe/EGR Pipe cutoff and weld, #85 jet, and smooth boss. I did open up the airscrew. I don't think my exhaust has a washer restriction but I have a 2T.
Also, thanks for making this forum active again.
« Last Edit: August 05, 2014, 11:53:54 AM by Chris0381 »
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
aaron8
« Reply #2 on: August 05, 2014, 03:16:30 PM »
the 2014 2ts are coming with a washer welded inside the exhaust
nuggzy
    • photobucket
« Reply #3 on: March 28, 2015, 10:51:37 AM »
Hey there curious if you found any final gears yet , same as you i have done just about everything to this scoot
possible even found bigger intake from kymco i get up to 40mph no prob. Then slowly
climb up to the fifty mark but thats it so whats next. Gears
2013 Super8 50 2t
full ncy cvt kit with all the bells and whistles 1500 contra and clutch springs relocated front an back turn signals into there proper spots (the fake turn signals) looks sharp..70cc bbk , 20mm intake , 17.5mm  carb.  ,motosport  adjustable brake  handles ,cleaned up tail , leds
Chris0381
« Reply #4 on: March 28, 2015, 12:43:21 PM »
Link for that setup. I just want to look at it. Not ready for a new carb upgrade but real close to considering one.
Smooth Boss
Polini Variator
#95 Main Jet
chaz35
  • old guy
« Reply #5 on: March 28, 2015, 03:48:42 PM »
I think the exhaust is holding you back.  70cc BBK's still running OEM exhaust?, anyone running Tecnigas pipe?
What year is you S8?  2 strokes after about 2005 are heavily restricted for EPA rules and don't run as well as earlier engines.  Same engine, still capable of running great, just needs a few more mods.  I have 2005 People 50 2Tand runs 50mph with only mods: cdi destricted, 85 main jet, the OEM exhaust doesn't have any restrictions and works great.  I think your S8 50 2T has the same engine, so should be able to go a lot faster IMO.
I am looking to buy a used 2013 S8 50 2T, so I am interested in your issues.
Chris0381
« Reply #6 on: March 28, 2015, 04:14:27 PM »
Chaz
I think there was something diff about the 2005 People's carb-manifold that gave it more power than the Super-8. Im not really clear on what it was as I think both carbs were 16mm.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #7 on: March 28, 2015, 06:00:03 PM »
The people 50 before 2007 came with 18mm carb and after they were 16mm. It's a good upgrade to the newer 2t to switch to the old style.
Chris0381
« Reply #8 on: March 28, 2015, 06:11:34 PM »
Then thats like a nice clean upgrade. Let me see if I can can get my seasonal job back and I'll look into doing that People upgrade to the Super 8. I thought I looked at an old pre 2007 people's spec sheet and saw 16" somewhere.  I downloaded the wron manual.
What I see here http://www.bikez.com/motorcycles/kymco_people_s_50_2006.php is the 2006 People has 3.72 HP vs the 2013 Super 8 at 1.50 HP. Thats quite a bit more power.
I think a pre-2007 People carb and minafold is the way to go if your not doing a BBK, an exhaust with an expansion chamber and open air filter and are sticking to a basic de-restricted exhaust.
« Last Edit: March 28, 2015, 06:31:15 PM by Chris0381 »
Smooth Boss
Polini Variator
#95 Main Jet
