Author Topic: Super 9 nightmare pls help !  (Read 6379 times)
Mroz
« on: August 05, 2014, 01:17:12 AM »
Hey  guys...
So this " master piece "what i just got is really killing me big time !
Scooter have really hard hard hard time starting !
It starts better with starting fluid but just little still lot of kicking
Starter cranking and it sound like its starting but it just wont catch the blast ...
Its a 70 cc with arreche carb stock pipe stock cdi stock air filter !
When start it runs and idle really good its just the starting thing :/
After few minutes riding it usually starts right away
Battery good
Spark plug good
Starter good
Having spark all the time
Fresh gas
New fuel filter+ hoses
New air filter
Getting fuel when cranking
Carb cleaned up like 3x already
Choke was on battery it did move ( but the whole choke bracket in carb is very lose ???)
Well what would u checked next ??
Valve? Rings ? Head gasket? Can this be problem?
Every opinion would be very appreciated !
Mroz
Re: Super 9 nightmare pls help !
« Reply #1 on: August 05, 2014, 11:56:19 AM »
Forget couple things :
Sometimes like this morning scooter starts on first kick but always when cold i have white smoke from pipe and bad gas smell ... Well scooter smell like gas always when idle ?? Too rich? Or bad rings?
Any idea?
Thx
supercobrapaul
« Reply #2 on: August 12, 2014, 04:05:02 PM »
It wouldn't hurt to check the compression.
If a hammer doesn't fix it, it's an electrical problem.
Mroz
« Reply #3 on: September 01, 2014, 11:24:21 PM »
Ok, so i checked a lot of things ,
Head gasket was bad so i replace them ...
So new info :
Scooter have problems starting only when cold !
But it starts good with fluid !
Choke works
I have 19mm arreche carb
And stock air filter without any air intake ( rubber hose with a box )
I adjust air mixture screw few times already
Spark plug getting kind of black rich
So mu question is about air set up on 70 cc airsal with 19mm arreche do i need anything special ? Like foam filter or breather or just more or less air ?
I cant find anything online about the air setup
Thx
MaryK
« Reply #4 on: September 02, 2014, 12:03:17 AM »
If it doesn't like to start cold but is ok when warmed, then the possibility is:
1.  the choke system isn't working, so clean the carb.  That also agress with the better starting using ether.
scoot safely,
New Rider in 2010
2009 GrandVista 250
« Reply #5 on: September 02, 2014, 12:06:25 AM »
Sounds like either bad choke or tuned too lean. Could be low compression too, you want minimum 125psi with a kit. Adjust the mixture richer and see if that helps, also you said the choke it's lose? Check and see if ii's missing the o-ring.
Mroz
« Reply #6 on: September 02, 2014, 01:12:08 AM »
Well i have no compression tester but piston have brown marks under ring so ill order new one ...
And yeah choke was lose so i glued the bracket on the carb today and redid the carb again :/
The thing is when i start cold it smokes ,took long time ( few sec) to get in higher ( good ) rpms with full throttle after that it runs goood
Ill see in the morning whats new
Thx
« Reply #7 on: September 02, 2014, 02:32:19 AM »
What oil do you use? Also if the white smoke smells kinda sweet it's got a bad head gasket and is burning coolant
Mroz
« Reply #8 on: September 02, 2014, 11:47:15 AM »
Well i use regular cheap 2 stroke oil no premix
And i just change headgasket and its AC scooter
This morning scootr starts righ away and after 3 minutes it bogs down and no more starting
But i can hear its trying :/
Ohhh this is nightmare !
« Reply #9 on: September 02, 2014, 01:13:13 PM »
Yeah you have to check compression dude. Also don't cheap out on two stroke oil, this kinda stuff happens.
Mroz
« Reply #10 on: September 23, 2014, 07:26:04 PM »
Compression checked 75 with el start
~ 90 with kick start so i assume piston ?
« Reply #11 on: September 24, 2014, 03:56:47 AM »
Rings and cylinder, maybe piston too. You should do the wrist pin bearing what head/base gaskets while in there too
maddog21
« Reply #12 on: September 28, 2014, 05:52:20 PM »
When you put new top end on this time buy senthetic 2cycle oil it will help in long run
Mroz
« Reply #13 on: December 16, 2014, 11:02:55 PM »
Ok i am back with my super nine ac
So new piston + ring , gaskets ......
Still same thing , scooter have hard time start when cold
When does it start it runs a restart fine ...
What i found out is : if i pull out el. Choke from the carb ( 19mm arreche )
The scooter starts right away when cold , when i put the choke back it still running ,
Wheni turn the scooter off a put the choke back it wont start again ...
What that means ?
Too much air ? Air leak ?
Thx for any info
« Reply #14 on: December 16, 2014, 11:17:26 PM »
What that means ?
Thx for any info
If anything to much fuel, if you take out the choke it leaves a HUGE hole for air, if it runs good like that your too rich. What pilot just and main jet and needle position do you have? Also stock airbox or pod filter?
