Author Topic: terrible noise  (Read 1666 times)
gnvernon
  • 2012 Kymco Super8 2T
terrible noise
« on: August 05, 2014, 02:25:18 PM »
The top speed of my 2012 2t was around 36-37 but I dont have the balls to get it up that high anymore because as soon as I hit 32 mph, there is a nasty sound coming from the variator. It slmost sounds as if it is clunkng. Any ideas as to what this could be?
Chris0381
Re: terrible noise
« Reply #1 on: August 05, 2014, 02:36:57 PM »
Did you open up the case yet to look inside ?
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
gnvernon
Re: terrible noise
« Reply #2 on: August 07, 2014, 02:06:20 PM »
I have yet to open it up. I took a video of the sound and posted it on youtube. It can be found here ()
With all of these mods coming soon I dont wanna be stuck at 33 MPH! PLEASE HELP!!
Chris0381
Re: terrible noise
« Reply #3 on: August 07, 2014, 03:16:27 PM »
I'd be afraid of you being stuck at 0 MPH with that sound and damage to other components inside that case. Why haven't you opened the case it take 3 mins to do?
Smooth Boss
Polini Variator
#95 Main Jet
gnvernon
Re: terrible noise
« Reply #4 on: August 07, 2014, 03:21:59 PM »
I've been bogged down with work these last four days. Planning on opening it up today
Chris0381
Re: terrible noise
« Reply #5 on: August 07, 2014, 03:29:06 PM »
Something sounds loose and metallic in there. Could be the variator or clutch nut loosening. Starter pinion and works would be a guess also.
Smooth Boss
Polini Variator
#95 Main Jet
gnvernon
Re: terrible noise
« Reply #6 on: August 07, 2014, 03:30:05 PM »
starter pinion and works?.........
Chris0381
Re: terrible noise
« Reply #7 on: August 07, 2014, 04:11:07 PM »
Do a little research on whats inside that box, there is a bit that can come lose. You'll find some youtube vids and pics.
Smooth Boss
Polini Variator
#95 Main Jet
AussieChiller
Re: terrible noise
« Reply #8 on: November 16, 2014, 11:48:08 AM »
Sorry to thread dig, I bought a 2012 Super 8 2T about 2 weeks ago and it has been modified by the previous owner, only thing I can see is that it has a Technigas exhaust and it makes the same kind of noise yours does, its only does it above 60kmh and when taking off from a stand still and only when its warmed up.
Did you ever find out what it was?
Ive opened the case and have had a look inside but nothing seems out of the ordinary or broken, is it possible the belt is hitting the kickstarter pinion?
