Did you miss your
activation email
Scooters - 125 to 300
Xciting 250
Stupid engine question.
Topic: Stupid engine question. (Read 1631 times)
arcanum70
Full Member
August 05, 2014, 06:44:50 PM »
I remember seeing on here somewhere that the xciting 250 is the exact same motor as one of Kymcos other bikes, but for the life of me I cannot remember which one and I cannot find the thread where it was mentioned. If anyone knows and could tell me it would be appreciated.
Thanks.
Build a man a fire and you keep him warm for a day. Set a man on fire and you keep him warm for the rest of his life.
Carter Merz
Re: Stupid engine question.
August 05, 2014, 08:10:13 PM »
The Xciting 250, Grand Vista 250, and Bet & Win 250 all share the exact same motor. People 250 and s250 have very similar engine to Xciting but I believe the cylinder and head are different. All 250 cvt components are interchangeable.
arcanum70
Full Member
August 05, 2014, 10:16:46 PM »
Thank you SO much. I just figured if I knew then I could just get that service manual since I cannot find one for the '07 xciting 250. Also I have found after market engine upgrades for those, but not mine...if it's the same engine then the parts will fit.
Thank you again.
2wheelfun
Reply #3 on:
November 30, 2014, 12:14:07 AM »
No such thing as a stupid ?, only excuse is ignorance.
Urbestfriend
Sr. Member
Reply #4 on:
December 01, 2014, 02:21:11 PM »
Parts List Tip....It appears that Kymco assigned part numbers for various models when they were released. Therefore my GV and X-250 (same engine / same parts) have had different part numbers. However you'll now see notes that may say: "Call for Price"...hopefully they are consolidating parts so they have a common part number over the various model lines.
Back
