Author Topic: weird noise coming from rear of scooter  (Read 6814 times)
gnvernon
  • 2012 Kymco Super8 2T
« on: August 06, 2014, 03:13:40 PM »
Whenever I hit around 32-33 MPH my scooter starts to make a metallic noise that sound kind of like "whoa-whoa-whoa-whoa" and gets faster as revs get higher if I try to fight through it. It sounds like it might be coming from the CVT area but I cannot pinpoint it exactly. Any ideas what this could be and if I need to take care of it before I ride it anymore? Thanks
MN_Scoot
Re: weird noise coming from rear of scooter
« Reply #1 on: August 06, 2014, 05:08:50 PM »
I've had two similar sounds. One was the muffler cover and one was the kickstarter.
For the muffler cover, you can be sure all the bolts are tight, but I found the only way I permanently got rid of all remnants of the tinny sound it makes at some rpms was to take it off. You can check to see if this is your sound by putting pressure on it with your hand or a boot immediately after you start the engine before it gets too hot.
The other time I heard this sound, the kickstarter piece that folds out wasn't completely closed into the riding position and was making a metallic sound as it rattled against the center stand.
Hope it's that simple for you.
2007 Kymco Agility 50
Stock other than Dr. Pulley Sliders and derestricted from the dealer.
gnvernon
« Reply #2 on: August 07, 2014, 02:36:04 PM »
for any of you that might have insight, I have posted a video on youtube with the sound. Please take a listen and let me know what you think
DMblues01
  • 2012 Kymco Super 8 150
« Reply #3 on: August 07, 2014, 02:56:25 PM »
This is going to sound dumb, but I had a similar sound with my Super8 150 at about 50 mph.
I went through and checked for loose screws and bolts, and couldn't figure it out.
So I cleaned out the under seat storage compartment, so I could take it up to the dealer, and the sound magically disappeared!
Turns out, in my case, it was some of my junk vibrating against the tub under the seat so it sounded like an engine noise.
I don't know if you keep stuff under your seat all the time, but if so, take everything out and see if the noise is still there.
Hope your's turns out to be a simple thing like mine was. Keep us posted if you find the culprit for sure.
Sorry I can't be more help.
Duke- 8)
Roxana, IL
Yoda is my spiritual leader.
DMblues01
« Reply #4 on: August 07, 2014, 02:59:59 PM »
Also, I just thought, make sure that the rubber bumpers on the side stand and center stand are intact.
If one of them is missing, the stand could rattle against the frame and/or engine case.
Duke- 8)
Roxana, IL
gnvernon
« Reply #5 on: August 07, 2014, 03:20:54 PM »
I felt my CVT while I was riding and could feel it coming from there.
DMblues01
« Reply #6 on: August 07, 2014, 03:34:22 PM »
How many miles are on the scoot?
If the belt is worn down enough, it could be belt flutter from being too loose.
Grabbing at straws at this point.  ???
Duke- 8)
Roxana, IL
gnvernon
« Reply #7 on: August 07, 2014, 03:41:46 PM »
1850
wkreps
« Reply #8 on: August 07, 2014, 07:28:47 PM »
I had a similar sound. Took it  to my dealer and told him the passenger pegs springs were broke too. He replaced the pegs and the sound went away. I still can't believe it but the sound hasn't returned. Try taking off the passenger pegs. Here's my vid for comparison.
Wayne
Chris0381
« Reply #9 on: August 08, 2014, 12:19:58 PM »
I dont plan on taking liability for a passenger so I took off my pegs and grab bar all together.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
boo
with all those viberations
« Reply #10 on: August 09, 2014, 09:48:12 PM »
I would look at a loose axle nut or bad wheel bearing.
300GTI black
Pro 2A - member GOA & NRA
« Reply #11 on: August 10, 2014, 11:48:48 AM »
Might be worn rollers.or belt.after a good speed your belt will hit the starter bendex.
gnvernon
« Reply #12 on: August 14, 2014, 01:48:08 PM »
This is the exact same sound that I have. It was your passenger pegs? the springs on mine are still fully functional
wkreps
« Reply #13 on: August 15, 2014, 06:54:47 PM »
It's easy to test. Two hex screws on each one and they come right off. Take them off and see if the sound goes away. I had a hard time believing my dealer but the sound is gone. It was under warranty and I got a service receipt in case it ever comes back. The thing I can't figure out is why would they fib about it? I can't see any indication that they took off the CVT cover so what am I to think? Give it a try.
Wayne
MoToFaLcon
  • I Fly....
« Reply #14 on: August 22, 2014, 05:46:20 PM »
Same for me on the a50. @ 28mph-34mph. Sounds like a paperclip scraping on concrete for me. If it went away, my scoot would b perfect.
WTF, i have a Ninja 650!!
