Author Topic: CVT belt life expectancy?  (Read 10151 times)
Chris0381
Re: CVT belt life expectancy?
« Reply #15 on: August 17, 2014, 01:39:27 AM »
When ever you change your belt, how does everyone go about torque on the nuts? Guessometer or torque wrench?  Hoping for guessometer lol, i hate torque settings.  ::)
I use a variator holding tool and 1/2" HF torque wrench to 40 ft/lbs plus and extra click or two. I only replaced mine after 1500 miles to have a spare in my storage compartment that I should be able to replace roadside.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
« Reply #16 on: August 17, 2014, 05:48:09 PM »
I've ALWAYS used impact wrench, 3/8 electric never stripped a variator nut out had one come loose.
Chris0381
« Reply #17 on: August 17, 2014, 08:39:37 PM »
I dont have an impact wrench but after removing my variator twice already, I feel the variator nut comes loose because some people tighten the pulley on the belt with out compressing the torque spring to ensure the belt is lose. An Impact wrench is on the to buy list though bettin, I agree its much easier and faster.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #18 on: August 19, 2014, 07:34:26 PM »
I use an impact wrench to remove the nuts but always use a torque wrench to tighten them.  I currently have 10,500 miles on the belt of my Super 8 150.  I will be changing the belt, rollers and sliding blocks soon.  I changed the original belt after only 7000 miles but that was way to soon.  It still looked like it was new and had no noticeable wear.
kfc.android
Re: Years Versus Miles
« Reply #19 on: August 19, 2014, 08:47:37 PM »
Applied Walmart SuperTech grease to clutch torque driver bearings and starter bendix.
I didn't see that we need to apply grease on my service manual, is it a must to do that? If so, I will need to do it as soon as possible.
« Reply #20 on: August 20, 2014, 01:55:33 AM »
If you're going off the dash that's kms not miles.
« Reply #21 on: August 20, 2014, 02:55:23 AM »
The ODO on my Super 8 reads in miles, not kms.
MassScoot
« Reply #22 on: August 20, 2014, 08:52:01 AM »
Like I mentioned....Every 7,000 miles is about right.
Gloucester, MA. (Home of the Perfect Storm)
2012 Silver Kymco GT300i (Biondi Windshield/Shad SH40 Cargo Topcase)
2015 White Honda PCX150 (Shad SH37 Topcase)
2013 Yellow Lance PCH125 (Shad SH33 Topcase)
