Did you miss your
activation email
Scooters - 125 to 300
People 150
headlight bulb replacement help
Topic: headlight bulb replacement help (Read 3527 times)
littlejoeyrimshot
Newbie
August 08, 2014, 06:55:53 PM »
is it simple to replace the headlight bulb? i need help in how to access the assembly
thanks
littlejoeyrimshot
Newbie
Re: headlight bulb replacement help
August 10, 2014, 01:53:41 PM »
I have a 2007 Kymco people 150, sorry for forgetting this
leroyneal
Newbie
May 10, 2015, 04:30:21 PM »
Anyone?
I am struggling here as well.....
leroyneal
Newbie
Reply #3 on:
May 10, 2015, 04:43:57 PM »
Any instructional videos to share? I have searched youtube and super8 is all I get .......
Carter Merz
Reply #4 on:
May 10, 2015, 04:44:57 PM »
You have to take the two clam shell headset pieces apart, the front one with the bulb lifts forward. One screw in front below the headlight, two screws in back. And you have to remove the turn signals. The top of the front then prys apart gently.
leroyneal
Newbie
Reply #5 on:
May 10, 2015, 05:16:14 PM »
You are awesome I have all screws (probably more than I need) I am scared in how to safely get the front underside apart from the red front clam shell body part... it unsnaps? I do not want to crack it
Last Edit: May 10, 2015, 05:53:34 PM by leroyneal
leroyneal
Newbie
Reply #6 on:
May 10, 2015, 05:54:31 PM »
underside is loose ........
Carter Merz
Reply #7 on:
May 10, 2015, 06:44:50 PM »
The black WILL NOT COME OFF!!!! There are hidden screws for the black half. The RED half pops forward, pry from the top of it and it will "pop" off the black part if you have all the screws out. Again with turn signals off too.
leroyneal
Newbie
Reply #8 on:
May 10, 2015, 07:16:22 PM »
Thanks again !!
I will now give it a go !!
I am amazed there are no youtube videos on this for the P150
wish me luck !!
leroyneal
Newbie
Reply #9 on:
May 10, 2015, 09:43:30 PM »
Thanks BettinANDlosing altho you are a winner in my book !!
it is people like you that make these forums work
thanks again
Carter Merz
Reply #10 on:
May 11, 2015, 01:10:03 AM »
ðŸ‘ðŸ‘ðŸ‘💨
Back
