Author Topic: Dead battery  (Read 1221 times)
houndguy
  • Fear the mangy mutt!
  • Your idiotism amuses me.
    • Scooter Revolution!
Dead battery
« on: August 08, 2014, 11:03:52 PM »
Can I jump this battery?  Or do I need to simply replace the whole battery?
Just another scooter blog - http://www.2smallerwheels.blogspot.com
Urbestfriend
Re: Dead battery
« Reply #1 on: August 09, 2014, 12:27:41 AM »
I have in the past.  Interstate Batteries says be careful charging these small batteries at higher amps. They only last 2-4 years.  Just spent around $75.00 on a new one.  Unless you unintensionly left something on to discharge it,  Recommend a new one.
houndguy
Re: Dead battery
« Reply #2 on: August 09, 2014, 01:17:25 AM »
Yea, that was what I was thinking.   :-[
Now is there a video or something that will show me how to replace this battery (it seems easy enough to do) but not being mechanically inclined I want to make sure that I'm doing this correctly.
I've replaced enough car batteries in my day that it should be easy enough.
darkjeep
Re: Dead battery
« Reply #3 on: August 10, 2014, 02:25:55 AM »
You know replacing the battery on a 2010 xciting was easy.
Open up seat lid.
Two screws on the back open the battery door.
Then there is a battery strap and the cables running to it to remove.
I did mine in 20 minutes going slow and adding acid to my new battery.
Compared to the Yamaha Majesty this was easy and enjoyable.
houndguy
Re: Dead battery
« Reply #4 on: August 10, 2014, 07:48:57 PM »
Thanks to someone in the park where I live I was able to use a battery tender and recharge it.
Saturday I rode it for about 25 miles just to make sure it was OK.
Today, Sunday 08/10/14, I'm not able to ride due to heavy thunderstorms.  Here's hoping tomorrow is a better day.
Re: Dead battery
« Reply #5 on: August 10, 2014, 08:04:07 PM »
The Xciting 500 is a HUGE engine for a ctx14 battery, especially if it is the EFI version. I would not trust a sketchy battery.
