Author Topic: Installing a big bore kit and variator  (Read 3464 times)
kimura
  • 2012 super 8 50cc 2t
« on: August 11, 2014, 12:33:40 AM »
I asked this question in the super 8 section but I'm asking again hoping it gets more views in this one.
I'm bringing in my kymco 2012 super 8 50 cc 2t,  to have a 70cc big bore cylinder installed and a performance variator. The shop where Im having these installed is not the place where I purchased my scoot, its just a random motorcycle repair shop. When I was there I looked around and didn't see any other scoots, only motorcycles.
I'm a little concerned that the mechanic working on my scoot might be performing this job for the first time.
To make things easier I was wondering if it would help if I dug up whatever info I could  find on these installs on the internet, print it out and
bring it to him.
Or is the work to be done so straight forward that my concerns might be misplaced? what do you guys think?
Re: Installing a big bore kit and variator
« Reply #1 on: August 11, 2014, 01:44:24 AM »
If they can't put on a 70cc kit in a scooter, they shouldn't be allowed to work on a motorcycle. 70cc kit install is a breeze in that bike. Make sure you mention champhering the ports, this it's important for longevity. Also are they going to jet your carb too?
Chris0381
« Reply #2 on: August 11, 2014, 01:47:01 AM »
Did they say they will do all the other stuff needed for a successful BBK installation. Anyone can tighten the head bolts and install the kit. Doing it with all the other needed mods is important what I read not what Im experienced on.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
kimura
« Reply #3 on: August 11, 2014, 02:03:12 AM »
bettinabdlosing, i will mention chambering the ports, i bought a #85 main jet and will be giving it to them to install.
Chris0381, thats what I mean, should i look up the steps and bring them a print out?
Chris0381
« Reply #4 on: August 11, 2014, 10:56:08 AM »
Yea
Can anyone chime in on what other mods or component changes desirable for doing a BBK on a Super 50 CC 8 2T?
Smooth Boss
Polini Variator
#95 Main Jet
245luigi
  • Boston, MA
« Reply #5 on: August 11, 2014, 01:53:33 PM »
I can definitely speak for the LIKE BBK install. SHould be very similar for a super 8. Upgrade carb to around 19mm, upgrade intake, upgrade exhaust, chamfer cylinder ports. I personally zip tied 100% open my oil pump.
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
kimura
« Reply #6 on: August 11, 2014, 02:03:51 PM »
thanks for the info guys.
But I'm keeping the stock carb, stock intake, stock exhaust.  I will def mention the cylinder ports.
Anything else?
245luigi
  • Boston, MA
« Reply #7 on: August 11, 2014, 02:08:11 PM »
Interesting concept...does not compute... lol
Well if thats what your doing then just chamfer the ports and get more oil in there either through premix (involves jetting adj) or opening up the oil pump (either set it to provide more oil than usual at a certain throttle setting or 100% open all the time).
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
« Reply #8 on: August 11, 2014, 03:36:37 PM »
Without an exhaust out carb you shouldn't tie it open, be fouling plugs like a biotch. Just set it as high as it goes on the adjuster cable. Although you should ruin a 1% premix on your first tank for break in. Have you derestrcted you're exhaust?
kimura
« Reply #9 on: August 11, 2014, 03:40:36 PM »
thanks for the info bettingandlosing, no i haven't derestricted the exhaust.  All I've done so far is changed the smooth boss and the 82 main jet.
Chris0381
« Reply #10 on: August 11, 2014, 03:42:48 PM »
Kimura
Take a minute or 2 to fill out you scooter info in you signature if you can.
I just did that and it'll help other know what we have for mods etc.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #11 on: August 11, 2014, 04:07:53 PM »
If the cycle shop has a welder pay they them to restrict your exhaust. I did a write up on it search exhaust derestrction and show them, without it your kit will hardly make any difference. Also make sure you use a cooler plug, should say what plug to use in the instructions the kit came with. Usually a NGK BR9HSA, but read the instructions.
« Reply #12 on: August 11, 2014, 04:16:35 PM »
Chris0381
« Reply #13 on: August 11, 2014, 11:39:14 PM »
For some one just doing this mod with a smooth boss, would they want a jet bigger that the #82 and if so, what jet size would you recommend trying first.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #14 on: August 12, 2014, 12:00:42 AM »
Not if you keep the intake stock. But you may have to go higher than 85 with a 70 kit.
