Author Topic: Installing a big bore kit and variator  (Read 3473 times)
Chris0381
Re: Installing a big bore kit and variator
« Reply #15 on: August 12, 2014, 11:28:47 AM »
Not if you keep the intake stock. But you may have to go higher than 85 with a 70 kit.
Would pulling out the tube in the airbox be considered a nonstock intake? I should have mentioned that also. Just trying to figure what jet I should be running. Would a #82 jet be to lean for the your posted exhaust mod and removal of that tube in the airbox.
But by nonstock intake, I think you are referring totally bigger carb all together or open air air filter
« Last Edit: August 12, 2014, 11:59:33 AM by Chris0381 »
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
245luigi
  • Boston, MA
« Reply #16 on: August 12, 2014, 02:58:55 PM »
IMO 82 jet with exhaust mod and collett out is too lean. I did make a post about that a long time ago. I believe I was in the 100 - 102 range on the stock carb jets and was still running lean with nasty plug chops.
But Jets depend on location/altitude so for all I know you could be good. Check out plug chops and maybe even a cylinder head temp guage.
FYI intake is the metal manifold between the reeds and the carb.
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
« Reply #17 on: August 12, 2014, 03:17:32 PM »
Yes, that will be too lean. And I meant any intake mods, airbox or actual intake manifold.
Chris0381
« Reply #18 on: August 12, 2014, 04:13:10 PM »
Ok great, I'll keep the #86 in there.
Smooth Boss
Polini Variator
#95 Main Jet
kimura
  • 2012 super 8 50cc 2t
« Reply #19 on: August 13, 2014, 12:16:54 AM »
brought the scoot in, it should be ready on Saturday.
I bought 54 LED underglow lights to put under my scoot but he didn't want to install them because he said he didn't want to deal with any possible electrical problems, which I understand. Ill have someone else put them on at a later time.
Ive got my fingers crossed, lets see what happens.  :o
Chris0381
« Reply #20 on: August 13, 2014, 12:21:21 AM »
Can you can wire them directly to the battery with an inline fuse and switch so as not to touch any other wiring ?
Smooth Boss
Polini Variator
#95 Main Jet
kimura
« Reply #21 on: August 13, 2014, 12:31:57 AM »
I don't know bro, I suck at all things with tools involved and wouldn't dare try anything.
This is what I have.
