Author Topic: Wiring Question  (Read 802 times)
GBBBiker
Wiring Question
« on: August 14, 2014, 10:21:21 PM »
Do all Scooter manufactures use the same color code for wiring?
2wheelfun
Re: Wiring Question
« Reply #1 on: August 14, 2014, 11:06:34 PM »
No, that would be the cat's meow in a perfect world. Same with car makers.
GBBBiker
Re: Wiring Question
« Reply #2 on: August 15, 2014, 12:13:23 AM »
Right that would make it too easy.
Re: Wiring Question
« Reply #3 on: August 15, 2014, 04:31:37 AM »
Most use green for ground, that's about the only common wire color.
Re: Wiring Question
« Reply #4 on: August 15, 2014, 01:41:22 PM »
If your lucky green is gound white from the stator.red is hot and back to charge the battery.yellow and blue for lights and horn.
GBBBiker
Re: Wiring Question
« Reply #5 on: August 15, 2014, 03:20:53 PM »
Thanks all. I want to add led side lights and a high tail light/brake light.
