Author Topic: 50 2T Idle Screw  (Read 1280 times)
crazy8
50 2T Idle Screw
« on: August 14, 2014, 10:55:54 PM »
Where can I find the idle screw on a 2013 Super 8 50 2T with a stock Keihin 16mm?
Chris0381
Re: 50 2T Idle Screw
« Reply #1 on: August 15, 2014, 02:15:57 AM »
I believe its the only visible adjustable screw on the stick carb above right of the brass plug that hides the air screw/
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
crazy8
« Reply #2 on: August 15, 2014, 10:55:58 AM »
Thanks.  I just found another post that explained where it is and your post confirms this.  Now I just need to find a tool to adjust the D shaped air/fuel mixture screw.
rancer4
« Reply #3 on: August 18, 2014, 02:59:56 AM »
can i ask a question?  whats the airbox connection size on that carb?  is it really a 16mm venturi in it?  as compared to the usual 14mm that the bikes, that use these type of carbs got.  and whats the flange bolt hole center to center size?
rancer4
« Reply #4 on: August 26, 2014, 08:36:16 AM »
theres no information about super8 in america.  can you answer my question? get out a ruler and check for me please?  im using a japan market intake and airbox on my bike and the carb is 14mm.  just thought theyd use the same thign but if i can find a match then i aint ogtta deal with buying anoterh brand of carb and trying to tune it. since i already know how keihin pb tune
