Author Topic: wont stop running even with the ignition off  (Read 1084 times)
fkgomez
« on: August 14, 2014, 11:20:21 PM »
Hello,
My bike wont stop running even with the ignition OFF. I had to pull the battery in order to stop it.
After a bit I plugged the battery back in, with the ignition OFF and the starter motor started turning immediately. Bike did not start. Then, I switched the ignition to ON (without pressing the start button) the bike turned over. While it was running i noticed a loud humming noise sounded electrical.
So i think it might be that the starter relay is getting stuck?
hypophthalmus
Re: wont stop running even with the ignition off
« Reply #1 on: August 14, 2014, 11:32:25 PM »
Maybe you could try disconnecting the starter relay and using a jumper cable (or a screwdriver maybe) to start it to confirm that the relay is bad.
« Last Edit: August 14, 2014, 11:35:58 PM by hypophthalmus »
« Reply #2 on: August 17, 2014, 11:38:53 AM »
Internet scooter owners would call a miracle :-) !!
