Author Topic: Intake question  (Read 2852 times)
Scootsuper9
Intake question
« on: August 16, 2014, 05:57:58 PM »
Hi. I recently did a 70cc bbk on my super 9 lc. I currently have a tecnigas next r pipe stock airbox and 100 main jet on the stock carb. I just bought the malossi phbg carb kit amd was wondering what jets to run, where to get the dellorto jets, and were i can possibly get a 19mm intake to go with the carb. Keep in mind i will be getting an open air filter and any help will be appreciated thanks
Scootsuper9
Re: Intake question
« Reply #1 on: August 26, 2014, 10:07:53 PM »
Wow. Still no reply?
245luigi
  • Boston, MA
Re: Intake question
« Reply #2 on: August 27, 2014, 03:52:14 PM »
See signature below for starting point. Racingplanetusa has jets and intake
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
Re: Intake question
« Reply #3 on: August 27, 2014, 09:35:19 PM »
Don't run open filter, you wont gain anything but fuel usage. Also the PHBG carbs come setup for 4t with the 4t atomizer, get yourself the 2t atomizer setup and jet it for that.
245luigi
  • Boston, MA
Re: Intake question
« Reply #4 on: August 28, 2014, 01:40:17 PM »
To clarify my settings are on a 4t atomizer. If you go 2t atomizer does MJ tend to go up or down?
Also if you want a 2t atomizer I believe its better to order through dell'ortos distributor bc they'll set up the carb for you. Otherwise you can get the malossi kit, which is nice because it has all the additional parts for mounting etc. Then pick up at 2t atomizer. Mopedarmy has a guide on how to install it
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
Re: Intake question
« Reply #5 on: August 28, 2014, 03:26:09 PM »
Yeah moped army has awesome tuning guide for the phbg carb. In my experience the main jet needs to be smaller after switching to the 2t tube. Less air being introduced = smaller jet.
Scootsuper9
Re: Intake question
« Reply #6 on: September 22, 2014, 11:07:16 AM »
Ok well ive heard of people modding air box for much wider hoses to increase air flow and giving more performance. What jets would  u recommend for that?
245luigi
  • Boston, MA
Re: Intake question
« Reply #7 on: September 24, 2014, 04:33:13 PM »
Upjet and do plug chops. You can take the airbox restrictor out if you want
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
Chris0381
Re: Intake question
« Reply #8 on: September 24, 2014, 06:54:05 PM »
Depends on how much of the airbox you chop out and then isn't the filter being by passed. There is no chart for this much airbox chopped out = this size jet yet.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
Scootsuper9
Re: Intake question
« Reply #9 on: October 27, 2014, 12:33:25 PM »
Well ive been waiting about 3 months for my gear set to come in. Thanks scooter parts international, btw not recommended, i have a k&n air filter that fits perfect i just wanna know what jets for sort of a range to work off of, and once you get to a certain size with the airbox hose its not really recieving anymore air so what would be recommended jetting for a malossi phbg 19mm on a super 9 lc 70cc with an open air filter i absolutely love the sound of the intake without the airbox
Re: Intake question
« Reply #10 on: October 27, 2014, 06:05:12 PM »
On 70cc kits I have run between 38-52 pilot jets, and 95-162 main jets. There is no way to guess.
Order a set of 5 jets for each circuit for ball park ideas 38/42/45/48/52   95/115/125/135/145. Start w/ the biggest idle jet, and try to run it at LESS THAN 1/4 throttle. Keep swapping pilot jets till you can get a decent idle at near 2 turns out on the mix screw, and the bike will roll up to 1/4 throttle.
Next the main... Same story Biggest to smallest.
After you dial in a fair running set you will know what real jets to order. I have pilots in steps of one, and mains in steps of two. To really tune it get a set of needles, and tune the mid range after you get the jetting done.
Scootsuper9
Re: Intake question
« Reply #11 on: October 27, 2014, 06:29:54 PM »
Wow a real reply with a ramge of jets thank u that is what i wanted
Re: Intake question
« Reply #12 on: October 27, 2014, 08:54:40 PM »
I'm a life time member of "Zombies Keeping it Real" or Zkir....
Meatings (notice the spelling) Crawfordville Ramada. Sundays at noon. (we wait for the churches to empty)
Bring meat!
