Author Topic: kymco cobra blinkers/electric start not working (new to scooters)  (Read 723 times)
oakcity.cobra
I just got my first scooter today, a 50cc 2 stoke kymco cobra and the electric start and blinkers don't work. Didn't have any time to start taking it apart before it got dark so hopefully I'll have time after work tomorrow. Could it be a fuse? Do scooters even have fuses? It would make sense (in my mind) because the hi/low beams works, tail/brake lights works, dash lights working, everything except the blinkers and electric start. What components should I check? Any help is appreciated.
Re: kymco cobra blinkers/electric start not working (new to scooters)
« Reply #1 on: August 18, 2014, 04:41:27 AM »
Dead battery
Chris0381
« Reply #2 on: August 18, 2014, 11:38:32 AM »
Killswitch?
Loose battery connections?
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
