Did you miss your
activation email
Scooters - 125 to 300
LIKE 200i
Replacing 0.8A fuse on 12v charger
Topic: Replacing 0.8A fuse on 12v charger (Read 1275 times)
Groversmith
Newbie
August 19, 2014, 11:41:28 PM »
I think I blew the fuse to the glovebox charger, since it's not working and there are no other electrical issues. I heard that its inside the front cowl. Does anyone have instructions/pix of how to change it out and probably upgrade.
Carter Merz
Re: Replacing 0.8A fuse on 12v charger
August 20, 2014, 02:02:21 AM »
Never had to, you can possibly pop the 12v socket out and get it. While your in there replace it with a slightly higher amp fuse.
bluesin
2012 DT 300i
August 20, 2014, 01:04:33 PM »
I would guess you have to remove the Cowl asI did on my DT 300 .
I put a (Radio Shack ) 3 amp fuse in. The fuse is a SHORT (and NOT a Blade 0 fuse . I think Radio Shack is the only place to find them.
The .08 is pretty much useless if you want to use the outlet. I can run my GPS without worrying about blowing fuse , now .
"There is a Fifth Dimension beyond which is known to Man. It is a Dimension as vast as Space and as timeless as Infinity......It is an area which we call 'The Twilight Zone' . "Rod Serling
West Tennessee, USA
Reply #3 on:
August 20, 2014, 08:33:30 PM »
Somebody on this forum put a fuse holder in near the receptacle on his DT300i which makes great sense. He even had a picture of the result.
And yes, the front cowl has to come off to get at that fuse. I remember seeing it when I put the 'Wolo' horn on my wife's scoot. I don't recall noticing if you can remove the socket from inside the glove box.
Last Edit: August 20, 2014, 08:36:55 PM by CROSSBOLT
2011 300i downtown 82,265 KM.
Reply #4 on:
August 21, 2014, 03:37:10 PM »
they are called dash mounted fuse holder I picked mine up at a elec. supply shop,. drill hole and install ,. and then you can change fuse any time I put mine about 1 inch from plug, front or back of plug OK.
Back
