Author Topic: Agility 16" change brake bulb  (Read 1267 times)
ams_nsl
« on: August 20, 2014, 12:16:32 AM »
Hi guys,
Nice to meet everyone, I'm new to this forum.
I tried to change my brake light to a LED one from RMS, I removed the 6 screws holding the plastic cover and it won't come off.
Is there any trick to it, I'm afraid not to damage the plastic if I pull too hard. Did anyone else struggle with it?
Thanks!
Re: Agility 16" change brake bulb
« Reply #1 on: August 20, 2014, 02:26:21 AM »
There may be a plastic clib you have to push in on.after screws are out.
ams_nsl
« Reply #2 on: August 20, 2014, 09:48:03 AM »
I thought so, I'll try again tonight, It would be very helpful to know where that clip might be positioned.
ams_nsl
« Reply #3 on: August 20, 2014, 06:27:27 PM »
No chance. I'm afraid I might break the plastic if I stick the screw driver in too deep. The manual doesn't say anything about any clip, just 6 screws and the plastic cover should come off.
It feels like it's holding on on the bottom part though, I've attached a picture from the manual. There are 3 more screws on the bottom of the tail light but to take those off I need to unbolt the mud protector which has even more screws. Did anyone else struggled with this? I feel I'm going crazy, as it should be a really simple thing to do, bulbs burn out all the time.
« Reply #4 on: August 22, 2014, 12:39:11 AM »
Wow yours is dif.mine only has 2 screws and the cover comes right off. Always a easy fix for me.
The moped learner
« Reply #5 on: August 25, 2014, 03:54:43 AM »
That's how my is to blue i never seen one like that
ams_nsl
« Reply #6 on: December 18, 2014, 02:34:20 AM »
Still haven't figured it out. It's really frustrating. I'm happy the original bulb isn't shot :)
« Reply #7 on: December 18, 2014, 05:01:35 AM »
It's NOT the lens that comes off. You have to remove the casing/shell from the bike, and the bulb is replaced from the back. The lens is also held on w/ four clips. You will see them once the casing is off the bike. It doesn't matter if you break the clips. They only align the lens for factory assembly.
Welcome to the forum!!!
