Hey All,
Just thought I'd say hello <waves>
I ran across this forum when I was researching scooter models to choose from. I had also browsed different threads within this forum as well.
I just purchased my first scooter over the weekend; a brand spankin new 2013 S8 150 (5 miles on the OD). Started my break in on Sunday, a whole 26 miles (kept speed under 40mph and varied throttle).... lol
Attempted to start my commute to work yesterday (tues) on the scooter, but experienced a mechanical issue; reached speed up to 45mph and motor decided to shut down. Fortunately, traffic was not too heavy and I was able to make it safely to the side of the road. I was able to restart the bike a moment later and then make my way back home. Well, on the way back, the motor shut down a couple more times (both above 40mph), but was able to get the motor started and was able to get home.
I had contacted the dealer and informed him of my experience, and replied that it's quite possible there may be or had some debris / particles in the fuel system that may have contributed to my issue. He said to keep riding it, as it may pass (think of passing kidney stones .... lol). His last comment was if this issue persists, to bring it in. Unfortunately, the dealer is nearly an hour away.
After getting home from work, I removed the trunk to inspect the carb area ... I had read of some carb threads that others had posted. Inspected all the hoses; from carb to air box, and to the gear box. Some hoses looked close to being kinked (near sharp bends), so I made some routing adjustments. I then inspected the carb, intake manifold, boot, and air box. All hardware securely fastened.
Shortly after, I took the scooter out around the block, and seems to run fine, as it did when I kept the speed under 40 mph. I do plan to add more break in miles this weekend, and also take it out to an isolated area (no traffic) and test the waters again ...... to see if I can repeat the issue.
Any how, I thought I would share with you all my experience. Who knows, maybe someone else here had the same experience that I may be able to learn from.
I will keep this thread up to date as to whether or not the issue persists.
Happy riding
