Did you miss your
activation email
recommend a belt for my 50cc
Topic: recommend a belt for my 50cc (Read 1194 times)
kimura
Full Member
2012 super 8 50cc 2t
August 20, 2014, 11:57:13 PM »
mechanic just installed a malossi 70cc and variator, he says I should change the belt too. can you recommend one for my scoot? 2012 kymco super 8 50cc 2 stroke.
thanks!
kimura
Full Member
Re: recommend a belt for my 50cc
August 21, 2014, 12:13:08 AM »
how about this one?
http://www.scooterwest.com/item_details/Malossi-Kevlar-Belt---Kymco-People-Agility-Like-Super-8-125-150-200/3708
kimura
Full Member
August 21, 2014, 12:21:48 AM »
I contacted the above link to see if it would fit my scoot and the gentleman said that I should keep my stock belt, thats its actually better than any aftermarket belt.
I appreciate his honesty, but how can that be?
ophelia
Sr. Member
Reply #3 on:
August 21, 2014, 12:27:05 AM »
Kymco already has top tier manufacturers like Bando or Mitsuboshi making their belts. Just sometimes people feel thrifty or adventurous and want to try others.
Me, always factory belts.
2011 Kymco Downtown 300i
Carter Merz
Reply #4 on:
August 21, 2014, 03:06:08 AM »
I agree, factory belt is perfect size every time. Gates belts vary in size even if it says the same size on the label. Gates even their premium belts slip a lot worse than stock belt. The service limit I think is. 17mm on the people 50 and I've had NEW Gates belts measure 17mm!!!!!
Chris0381
Reply #5 on:
August 21, 2014, 11:52:53 AM »
These guys shipped a good belt to me pretty fast at a good price.
http://www.ebay.com/itm/120865471814?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Hurleymotorsports in upstate New York
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
kimura
Full Member
Reply #6 on:
August 21, 2014, 02:16:58 PM »
mechanic says when he took apart my scoot to begin the work he noticed there was a lot of dust. After having put in my 70cc cylinder and variator he says something feels off. According to him, it revs high but doesnt seem to go anywhere. thats why he assumes the belt is slipping.
any ideas of what else it could be?
Carter Merz
Reply #7 on:
August 21, 2014, 03:50:28 PM »
Sounds like slipping. Have you installed a tighter torque spring to hold more tension on the belt? It's a must for 70cc kits.
kimura
Full Member
Reply #8 on:
August 21, 2014, 06:33:33 PM »
thanks for relying bettingandlosing,
yes, the variator came with a white spring. so you think i should get a new belt?
Carter Merz
Reply #9 on:
August 21, 2014, 08:56:24 PM »
Yeah, but stick with the factory belt from Kymco. You could spend a lot on a aftermarket belt that is worse than stock.
Back
