Author Topic: Starting with brake lever  (Read 1471 times)
24auhr
« on: August 21, 2014, 09:49:17 AM »
Hi all
today after starting the scooter i let it sit and idle for a while , maybe about 10 minutes while i pottered around doing other things
when i got back to the scoot i gave a bit of a rev and started a pre ride saftey check (like checking the brake lights ,indicators ,headlight ,brakes actually working)
when i squeezed on the brake lever i heard a terrible sound then tried it again to make sure
i turned off the scoot with the key then turned the key back on , then squeezed the brake lever and the scoot started !  without pressing the start button
i tried this again and it didnt reoccur , this time no bad sound while braking
i took it for a short ride around the block , stopped halfway and restarted , it started with just the brake lever again (both levers do this)
obviously theres a short or a bad switch somwhere and given that it happens intermittantly im hoping that this is my gremlin
(if youv read any of my other recent posts youll see iv been having a hard time starting)
also i read a few posts about looking for a stronger starter motor , , did anyone find the part no. for that ?or will any starter motor that will suit kymco 500ri work ?
thankyou everyone
Jeopardy4100
Re: Starting with brake lever
« Reply #1 on: August 23, 2014, 05:17:05 AM »
I would be looking for a sticking start button.  I believe this would be the logical place to start.  This could be confirmed with a multimeter.  If this is the case it could be a compressed contact or a lazy spring.
Jeopardy4100
MeTaeTer
« Reply #2 on: October 01, 2014, 09:26:01 AM »
Very good post Read I'm not easy to understand it.
Actually the matter very much. There are benefits to living it.
Urbestfriend
« Reply #3 on: October 01, 2014, 12:15:33 PM »
First of all,  Use the other brake lever and see what happens.  My switch wouldn't engage no matter how hard I squeezed.  We now have a new Kymco Scooter shop in town.  The cable/switch cost was $15+.  He suggested oiling it.  I did and it worked.  It's a small micro switch.  Look carefully in the Lever area.
« Reply #4 on: October 01, 2014, 12:40:21 PM »
You have a stuck starter button. OR a broken return spring inside the switch.
I would get a new assembly for 20 bucks rather than mess with it.
