Author Topic: not starting  (Read 3131 times)
rob1990
not starting
« on: August 26, 2014, 08:11:02 PM »
I have just brought a kymco agility 50cc all the lights work apart from a couple that need bulbs but there isnt anythink when you turn the key any ideas
tortoise
Re: not starting
« Reply #1 on: August 26, 2014, 08:58:55 PM »
Have you reviewed the owners manual?
Is the issue that the electric starter will not energize?
Have you tested cranking volts?
Have you tried kick-starting?
Please spell-check and punctuate text.
rob1990
Re: not starting
« Reply #2 on: August 27, 2014, 05:59:53 AM »
No there is nothing apart from the lights and horn working
MaryK
Re: not starting
« Reply #3 on: August 27, 2014, 02:00:04 PM »
To Repeat, Have you read the starting instructions ?
Turn on Ignition switch
Retract side stand
Hold left brake ON
push start button
(engine should start)
If nothing happens, try holding the right brake lever ON (bad switch in left brake ?)
New Rider in 2010
2009 GrandVista 250
gnvernon
  • 2012 Kymco Super8 2T
Re: not starting
« Reply #4 on: August 27, 2014, 03:06:56 PM »
Have you tried kick start? When my battery "died" (my power got too low) my lights still worked but when I would hit the ignition, nothing would happen. Try charging the battery and see what happens
rpm
Re: not starting
« Reply #5 on: August 27, 2014, 04:19:54 PM »
rob
check the kill switch by your right thumb and make sure it isn't on the kill setting.
rob1990
Re: not starting
« Reply #6 on: August 27, 2014, 05:52:42 PM »
Thanks for all your help im getting a ticking noise when I hit the button
gnvernon
Re: not starting
« Reply #7 on: August 27, 2014, 06:27:58 PM »
Clean the spark plug and try spraying something flammable where the spark plug goes. Helped me get mine started two days ago
Re: not starting
« Reply #8 on: August 28, 2014, 02:12:04 AM »
Is the clicking comeing from under the front plastic.
Re: not starting
« Reply #9 on: August 28, 2014, 02:15:21 AM »
Classic weak battery. Buy a new battery and you'll be golden.
rob1990
Re: not starting
« Reply #10 on: August 28, 2014, 06:25:01 AM »
Going to redo the wiring on the battery as someone has bodged it dont think they knew what they were doing,  then going to charge the battery then see what happens
rob1990
Re: not starting
« Reply #11 on: August 30, 2014, 04:40:44 PM »
Just a update charged the battery tried it still the same clicking noise coming fron the plastic under the seat any other ideas????
tortoise
Re: not starting
« Reply #12 on: August 30, 2014, 04:49:32 PM »
charged the battery . . still the same clicking noise
Cranking volts?  Try jump starting from a car battery . . car engine should NOT be running.
rob1990
Re: not starting
« Reply #13 on: August 30, 2014, 04:57:36 PM »
Will try that was looking online and was saying starter relay but dont kno where that is. Its my first bike  so am new to all this
tortoise
Re: not starting
« Reply #14 on: August 30, 2014, 05:34:54 PM »
starter relay . . dont kno where that is
Google
