Author Topic: when to replace drive belt?  (Read 2110 times)
speedee86
  • 2012 Kymco Xciting 500 RI ABS
« on: August 29, 2014, 03:47:07 PM »
hello fellow xc500 guys. question, at what mileage did you guys replace your drivebelt. i have just under 20,000 miles on my xciting 500 ri, on the original drive belt. i have had it inspected by 2 shops including the dealer and both said it looked good. i use it as a commuter so i would say about 80-85% of my mileage is freeway. what are your thoughts?
also when you replaced your belt, what else did you replace? what was the cost?
thinking i can do it myself borrowing some tools. i have swapped a variator on a super 8 150cc but this is a much more robust setup on the xciting 500. i still cant imagine it taking much longer than 30 minutes to install one.
any info, tips tricks are appreciated.
thanks in advance guys.
always leave yourself an exit incase you get stuck in a pinch. RIDE SAFE!
Re: when to replace drive belt?
« Reply #1 on: August 29, 2014, 04:46:08 PM »
Know nothing about a 500, but if one is looking at the belt - fully 1/2 of the work on changing it is already done!
Get yourself some new rollers and slide pieces, a new belt, maybe 2 new nuts, one of those 'holder' tools and have at it!
Don't put a time on the job in your mind. Take your time, have a coffee, look things over - this is your commuter.
At 20000 miles I would be changing the belt.
speedee86
« Reply #2 on: August 29, 2014, 07:35:54 PM »
Thanks stig, the dealer just checked it a couple weeks ago and it was well within spec so imma have the check it again soon when I am nearby and get one on order soon if even just to have on hand :) I will prpb get the rollers and slides also while im in there.
