Did you miss your
activation email
Scooters - 125 to 300
Downtown 300
Oil inside airbox
Topic: Oil inside airbox (Read 1376 times)
Powersport14
Newbie
Oil inside airbox
September 02, 2014, 05:39:09 PM »
I just noticed some oil on the gearbox next to the rear wheel. Took my air box apart and it had oil in it on the filter and on the bottom edge of the box. Oil appears to be leaking out of the air box and down onto the gearbox but where could the oil be coming from?
nushipwright
Full Member
Re: Oil inside airbox
September 02, 2014, 06:53:52 PM »
Have you changed gear oil recently?
if you over fill the gear oil the excess oil will be evacuated through a pipe into the back of your air filter box. on the bottom of the box there is a small hole where this excess oil will drip out and make the final drive housing messy...
the oil should not be able to soak your filter.
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.â€
- Mark Twain
mostly 2up city
2011 300i downtown 82,265 KM.
September 02, 2014, 07:52:53 PM »
two years ago I filled to the fill hole , and the oil was soaking the filter and dripping out the bottem, so measure the oil very carefully,.
Carter Merz
Reply #3 on:
September 02, 2014, 08:29:40 PM »
Don't forget to drain the airbox hose too, the clear one with a cap on the end. If oil is on the airbox it's in that hose too
kneeslider
Reply #4 on:
September 04, 2014, 06:11:44 AM »
The oil gets blown up thru the breather, instead of onto the road. It's normal.
2019 Yamaha X-Max 250
Back
