Author Topic: xenon light 35/ or 55 watt  (Read 6627 times)
Mysterio
« on: September 07, 2014, 12:15:46 PM »
hello brothers , actually i replaced my headlight beams yesterday with xenon lights but i ddnt find any 35 watts :-X so i got the 55 watt , and am wondering is there any problem with this replacement ? ??? ???
donjack
Re: xenon light 35/ or 55 watt
« Reply #1 on: September 07, 2014, 12:46:07 PM »
hello mysterio, I installed HID's a couple of days ago, they are 55w and, touch wood, I have not had any problems, just lots more light!!
hope this helps,
Don.
Mysterio
« Reply #2 on: September 07, 2014, 02:46:39 PM »
oh well that's great ,as i'm afraid to damage the battery or the wires dunno just fears  :ov
« Reply #3 on: September 07, 2014, 05:41:18 PM »
Nothing will get damaged, you might want to check your voltage at idle to make sure it's over 13v our you might run into charging problems. But the DT has a low battery light, so if that didn't come on while idling your good.
« Reply #4 on: September 07, 2014, 11:54:16 PM »
   the light # is H 8  for our scoots, and it is 35 W.   I installed HID lights , h 8 or h11 fits,.  I never tryed 55 w. might try that for high beam, what # did you use,   I have HID on low beam only, very good light pattern  side and front,
RubenC
« Reply #5 on: September 08, 2014, 03:19:38 AM »
Did you use a light kit or just replace the bulb?
From the Great Nation called Texas. Oops I mean the Great State called Texas
« Reply #6 on: September 08, 2014, 03:52:34 AM »
   I think you have to use a light kit, it needs 22,000 volts I think to start the light, then it takes the same 12 volt  to keep it lite,
 I ran wires from the battery to the lights to start, and wires from the headlite wires to keep it lite,. then I changed all the other lights to Led lights to keep the over all power watts down,.   the guy who installed 55 w. bulbs check the light housing for high heat, don't want to melt your headlights,.  just a thought?
donjack
« Reply #7 on: September 08, 2014, 05:59:22 AM »
Hello de dee, thanks for the info, I will check the light housing! Never gave the extra heat a thought! I'll keep you guys posted.
Cheers,
Don.
Mysterio
« Reply #8 on: September 08, 2014, 06:39:36 AM »
Well am not sure but I guess its H8 like the stock one
And I just replaced it with the stock without using lit kit , I dnt know what is lit kit tho  :o
And about the heat its normal almost less than warm
TLRam1
« Reply #9 on: September 08, 2014, 08:03:50 AM »
Does anyone know if a PS250 High Beam can be independently adjusted separate from the Low Beam?
Terry
10 Kymco People S 250
87 Yamaha Riva 200 (Sold)
Allen TX (Dallas)
cli-maxridinggear.com
« Reply #10 on: September 08, 2014, 01:01:51 PM »
The high beam and low beam are one bulb, so no they adjust together.
TLRam1
« Reply #11 on: September 10, 2014, 05:50:46 AM »
That's what i was afraid of, thanks.
Terry
Allen TX (Dallas)
donjack
« Reply #12 on: September 15, 2014, 04:56:49 AM »
hello guys, I managed to take a couple of pics of the 55w HID's, hopefully you'll be able to see them!! first pic is originals, second is the HID's.
I bought one of those modulating LED's for the brake light, I tried it and didn't like it, it didn't seem as bright. I have a very short video, and I will try and post to you tube, link to follow!
cheers,
Don.
« Last Edit: September 15, 2014, 05:03:40 AM by donjack »
« Reply #13 on: September 15, 2014, 05:29:36 PM »
That's sick!!!! I swear by the HID kits, and i will until LED slip ins get brighter and cheaper. The headlights on your DT look almost like a Yamaha R1!!!
donjack
« Reply #14 on: September 15, 2014, 07:00:52 PM »
Thanks mate 😊 I'm glad I went down the HID route!!
I'm sure with a few more mods I'll have her performing like an R1!!.....Now where did I put my spanner!!  ;D ;D ;D
