Author Topic: scoots down  (Read 2269 times)
Re: scoots down
« Reply #15 on: September 13, 2014, 04:49:46 AM »
Thanks zombie.I will check that out in a few days.im off work next week for vacation so ill have time then.
Re: scoots down
« Reply #16 on: September 13, 2014, 06:43:02 AM »
That's what Vaca is for... Fixing all the sh** that breaks during your work life.
Who made this system up?
Re: scoots down
« Reply #17 on: September 14, 2014, 07:05:43 PM »
Geting to the end of the rope with yhis scoot.I have spark.but week out put from stator.if the elec.relay is bad would that make the stator week.my guess is no.
Re: scoots down
« Reply #18 on: September 14, 2014, 08:27:49 PM »
If you have spark at all it is not the stator.
Re: scoots down
« Reply #19 on: September 15, 2014, 02:14:59 AM »
Looks like ill be pulling the head off for closer look.
Re: scoots down
« Reply #20 on: September 15, 2014, 03:10:54 AM »
Use a LONG straw, like one of those giant fountain drink straws, to direct the spray from Brake Clean or Carb clean into a glass. Once you have about one ounce pour that into the upside down heads ports one at a time (intake/exhaust) If any of that cleaner weeps thru the valve(s) you know where the problem is.
Re: scoots down
« Reply #21 on: September 15, 2014, 07:13:19 PM »
The primary coil in the stator can be bad, i have a bike in the shop right now that does have spark but its super weak, won't even jump a few millimeters to ground. The primary coil was only putting out 40v ac.
2wheelfun
Re: scoots down
« Reply #22 on: September 15, 2014, 07:26:42 PM »
Do you know what the stator voltage a/cv should be, if 40vac is too low?
Re: scoots down
« Reply #23 on: September 15, 2014, 11:52:18 PM »
Tryed a new coil.got nothing did the same thing.im thinking bad valves.
Re: scoots down
« Reply #24 on: September 16, 2014, 05:31:24 AM »
Yeah from what I understand 50v ac will work but its weak, your want 100v ac ideally out of the primary coil.
