Author Topic: Kymco scanner  (Read 4910 times)
Re: Kymco scanner
« Reply #15 on: January 04, 2015, 11:57:29 PM »
Have you seen the flywheel on the efi Kymcos? They have multi-pickups and you wouldn't be able to use this as a reliable source for the standard pickup coil, not easily at least. Anything is possible, but it would be a bitch to go back to carb on any of these. If you got a really high end ignition setup then it might have parameters for multi pickup but then your looking at what, like $600 for ignition alone? Lol then a nice carb $100~. If o was gonna go all out on a 50i, first thing would be throttle body and injector swap, i bet anything that'd be 50mph out close to it on flat. The variator needs to be researched, possibly the same as other qmb/kymco style idk. The exhaust is very tiny, the header is pea shooter size, same with the intake manifold. Idk all of that is so expensive, and the efi system would be totally custom after the fact because the kymco one has the ecu attached to the throttle body directly. You could go buy a crate qmb, 4v head, big bore, big carb, for the same as what I listed before haha. Realistically with what the Cimpagno has on it, you can expect maybe 45mph TOPS on flat. The throttle body is so tiny.
Re: Kymco scanner
« Reply #16 on: January 05, 2015, 02:42:42 AM »
I never thought about the flywheel but now that you said "multi pickups"... One of them HAS to be a crank sensor so the ecu knows where the crank is in it's rotation.
That's how they establish a base line for variable ignition timing.
I still want one.
2wheelfun
Re: Kymco scanner
« Reply #17 on: January 06, 2015, 07:41:23 AM »
Anyone looked up a ssr piaggio 50cc. Those are fast............50cc scoots.
2wheelfun
Re: Kymco scanner
« Reply #18 on: January 06, 2015, 07:42:29 AM »
De dee sent you a pm.
Re: Kymco scanner
« Reply #19 on: January 06, 2015, 12:05:43 PM »
The SR 50 has been on my X-Mass list for a few years. I tried taking a few "pot shots" at Santa this year but I didn't realize he has a Kevlar suit. ::)
Maybe next year I'll try a snare on my neighbors roof.
2wheelfun
Re: Kymco scanner
« Reply #20 on: January 13, 2015, 11:25:16 PM »
SOLD!
Re: Kymco scanner
« Reply #21 on: January 14, 2015, 02:31:34 AM »
SWEET!
Who got it (so I can borrow it) ;)
Re: Kymco scanner
« Reply #22 on: January 14, 2015, 04:09:42 AM »
I bought it , its 20 below here I will be there soon,.
2wheelfun
Re: Kymco scanner
« Reply #23 on: January 14, 2015, 04:31:43 AM »
De dee here's a link to the user manual, scanner didn't come with one. Vesbretta is to be thanked, you'll need to use firefox to access it. Don't know why IE doesn't work.    http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/Downtown_125_i/DT125_13.pdf
Re: Kymco scanner
« Reply #24 on: January 14, 2015, 05:25:04 AM »
COOL! I'll have a pot of coffee, and a comfy chair waiting for ya! Glad to see the scanner found a deserving home.
