Author Topic: Should a agility 125 burn small amounts of oil?  (Read 1030 times)
bluescoot125
« on: September 12, 2014, 05:40:55 PM »
Since my last oil change I've ridden my agility 125 a little over 400 miles. And I just had to top the oil off is that normal? Not a lot but it wasn't as full as when I filled it.
Re: Should a agility 125 burn small amounts of oil?
« Reply #1 on: September 12, 2014, 09:14:06 PM »
Mileage on your scoot? And how do you ride it?
Intervals for doing those oil changes?
Type of oil?
These things can have an impact on oil consumption.
« Reply #2 on: September 12, 2014, 09:34:56 PM »
do a compression test, and pull off the cvt cover/fan cover. look for oil around the crank seals.
If all that is good then yes your bike is normal.
bluescoot125
« Reply #3 on: September 12, 2014, 10:53:04 PM »
Type of oil?
Mileage is 950km. I use 10w40 motorcycle oil. And I've only changed the oil once at 300km. Its a 2013 model and I usually ride about 45-55mph
