Author Topic: Outboard Oil in scooter?  (Read 2134 times)
joebro
« on: September 13, 2014, 12:15:21 PM »
I have recently been informed by my local auto parts store that Amsoil will no long be producing the oil I use in my 50cc Super 9 LC. Many people have recommended there outboard oil in the link below. Does anyone have any experience using this in scooters? Will I risk damaging my motor or a loss in performance?
http://www.amsoil.com/shop/by-product/motor-oil/2-stroke/outboard-100-1-pre-mix-synthetic-2-stroke-oil/?code=ATOBC-EA
You only live once but if you live right once is all you need.
Re: Outboard Oil in scooter?
« Reply #1 on: September 13, 2014, 12:52:03 PM »
I have suggested Yama lube for several years here. Outboard 2t oils are made for optimum protection in engines that run at or near full throttle. They are also designed to run at 50:1 ratios which is what most all injected scooters run at from 50% throttle up
08087
  • 09' Peoples 200, NJ
« Reply #2 on: September 13, 2014, 06:35:38 PM »
Just to add there are a ton of older 2 stroke outboards still running like a top, buy and use outboard oil without worry IMO, it may cost more (I don't know), but the protection you get will be the best option availible IMO.
« Reply #3 on: September 13, 2014, 06:55:15 PM »
70.00 US per gallon for Yama lube or 16.00 a pint for what I use... Golden Spectro Platinum 32.   No brainer
Chris0381
« Reply #4 on: September 13, 2014, 09:58:41 PM »
So Amsoil is going to discontinue both the Dominator and Interceptor types ?
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
08087
« Reply #5 on: September 13, 2014, 11:45:19 PM »
$70 a gal!!!!!!!!!!!!!!!!!!! Holy crap Batman! Stuff used to be cheap when I was a kid and had my 15 HP Johnson!
« Reply #6 on: September 13, 2014, 11:53:58 PM »
Ace Hardware here in town sells it for 68.99. The marinas are closer to 90.00.
When we were kids Bro, gas was 35 cents...
Don't be tempted for even a second to buy chainsaw or Walmart oil. It will foul, and score your cylinder in short order. That and the carbon it leaves...
2wheelfun
« Reply #7 on: September 14, 2014, 12:17:50 AM »
That's why they make 4 strokes!
« Reply #8 on: September 14, 2014, 12:20:00 AM »
100% correct.
2T's are 1/2 as efficient but twice as much fun.
08087
« Reply #9 on: September 14, 2014, 12:26:56 AM »
There is a purpose for both 2 and 4 strokes, the 2 stroke is great on small applications, light jon boats where weight is important and power down in the low RPM helps a bunch.
I could pull a skier with my 15 HP 2 stroke, doubt it would happen w a 4 stroker. (we were kids then)
joebro
« Reply #10 on: September 14, 2014, 10:33:05 AM »
Well after a lot of searching I was led to this page. I hope the link below will help anyone else trying to pick the right Amsoil 2 stroke oil.  ;D
http://www.thebestoil.com/AMSOILSynthetic2CycleOils/default.aspx?gclid=COSgwMfS3sACFShp7AodhH4Aig
Chris0381
« Reply #11 on: September 14, 2014, 11:37:20 AM »
Like my response above
Im surprised you were not running one of those. JASO and whats recommended I must add Saber also. I think switching over to synthetic (dominator) may have contributed to my 2 MPH gain as I'm still not sure where that gain came from but it was at the time I switched over to synthetic..
« Last Edit: September 14, 2014, 11:45:45 AM by Chris0381 »
Smooth Boss
Polini Variator
#95 Main Jet
