Author Topic: Fuel Shutoff valve - worth it ?  (Read 813 times)
Chris0381
« on: September 14, 2014, 02:03:13 PM »
A guy on youtube added a fuel shut off valve to his super-9
http://www.ebay.com/itm/like/390864555209?lpid=82
He claims it helps keep the carb clean. Would this be worth a good addition and does it really keep the carb clean ?
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
boo
does not make sense
« Reply #1 on: September 14, 2014, 03:58:45 PM »
You can cut the supply of fuel to the carb but, there would still be gas in the carb.
I guess one could cut the fuel supply then run the carb and engine completely dry.
A good carb/injector cleaner will do the same thing with less hastle.
« Last Edit: September 15, 2014, 01:16:05 PM by boo »
300GTI black
Pro 2A - member GOA & NRA
Re: Fuel Shutoff valve - worth it ?
« Reply #2 on: September 15, 2014, 03:57:46 AM »
There's no real advantage. I'm assuming he couldn't locate a replacement for the vacuum petcock, and added that instead.
If you want to run the carb dry just pull off the vacuum line.
Chris0381
« Reply #3 on: September 15, 2014, 03:58:11 PM »
Ah Zombie, I can see it as a theft control though. If the valve is shut of and not easily seen, someone quickly riding away with your scooter will be in for a surprise when it runs out of fuel.
Also a shutoff valve saved my life a long time ago when my buddy let me ride his supped up trailblazer and I was just going out of control off into the woods when it died out. He forgot to turn on the valve for me.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #4 on: September 15, 2014, 04:03:20 PM »
Valid points. Along the same lines you could paint a zebra brown, and call it a donkey.
I just don't see the need. ;)
