Author Topic: Belt restriction ??  (Read 1023 times)
ConradFr
Belt restriction ??
« on: September 14, 2014, 04:44:00 PM »
Hello
When i have changed the rollers into the variator of a Kymco Agility 50 4t 2014 it was difficult to put back the belt onto the variator.
It seems that the belt was too short and i need to compress the rear spring to engage the belt into the pulleys and now it was possible to put the belt onto the front variator
I have not readed the size of the belt but my question is
Is it normal that the rear spring need to be compressed to put the belt onto the variator ?
Is the size of the belt is volontary too short to limit the possibility  to run completely on the  rear pulley ?
And so limit the speed of the bike ? On the front pulley there is a small space +- 2mm on the top unused by the belt (variator is unrestricted of course)
Thanks for viewing
Bye
Re: Belt restriction ??
« Reply #1 on: September 14, 2014, 10:08:29 PM »
Everything you said is correct, and yes you do need to open the clutch some to get the belt over the crankshaft.
ConradFr
« Reply #2 on: September 15, 2014, 06:06:15 AM »
Hi
Thanks Zombie
But is it a normal way or the belt is too short ?
Nice day for all the members
Bye
« Reply #3 on: September 15, 2014, 07:21:54 AM »
You always have to squeeze the clutch in to install a belt.
When it fits properly the belt will be 1-2mm below the top of the clutch pulley, and wrapped snugly around the crankshaft.
The best way to verify it is all working right is to draw a few lines on the face of the variator with a Sharpie or other Magic marker. When you ride the bike for a mile or so the marker will wear off, and you can see exactly how far the belt is traveling.
It should erase the lines to within 1-2mm off the top of the variator.
That shows you everything is opening the way it should, and the belt is the correct length.
ConradFr
« Reply #4 on: September 15, 2014, 07:55:20 AM »
Hi
Thanks i will do that next time and see
Bye
