Author Topic: hesitating acceleration  (Read 771 times)
codger78
« on: September 21, 2014, 07:12:58 PM »
when I rev my engine there is a hesitation and the engine wants to quit
borrowed dust
Re: hesitating acceleration
« Reply #1 on: September 21, 2014, 07:46:54 PM »
Start with a carb clean, issues like that you need to have a good baseline to start tuning. After the carb it's good try adjusting the mixture screw. Start at 2 1\2 turns out and go from there. The agility tends to like a little richer than that but it's a good starting point. Check everything else, air filter spark plug etc.
