Author Topic: High beam module to allow high & low beam to turn on simultaneously.  (Read 1057 times)
kneeslider
Hello,
My DT's high beam switch when activated, turns off the low beams, unlike the PASS button which allows botht he low and high beams to remain on.
How can I get the high beam switch to activate BOTH the low and high beams?
2019 Yamaha X-Max 250
Re: High beam module to allow high & low beam to turn on simultaneously.
« Reply #1 on: September 24, 2014, 07:32:17 AM »
The easiest way would be to modify the switch wiring. Just swap the high beam wire with the pass wire, just look at the wiring diagram on the switch and pin out the two, click the terminals out of the connector and swap.
« Reply #2 on: September 24, 2014, 05:15:37 PM »
Hello,
  is there a switch that can replace the passing switch,to be able to turn the high beam on or off as you want ?
donjack
« Reply #3 on: October 30, 2014, 10:49:04 PM »
i was thinking about this mod too, so I have just had a look at the wiring in the switch, on my dt the wires are soldered, it make job a little more interesting/ difficult!!  :) :) :)
i might look into it a bit later.
cheers,
Don.
