Author Topic: please help.  (Read 1594 times)
Ahmad Mustafa
please help.
« on: September 27, 2014, 10:41:59 PM »
can the Malossi variator adjuster spring(white) be applied to the stock clutch?
Thanks
Re: please help.
« Reply #1 on: September 28, 2014, 04:09:40 AM »
Yes. That is a lighter than OEM spring however.
If you want to run that one you need very light rollers. That combo usually works well for heavier people.
If you try it w/ OEM rollers you will find a loss of acceleration, and a huge bog when going up hill.
Swap to light rollers, and performance will improve above OEM
Ahmad Mustafa
Re: please help.
« Reply #2 on: September 28, 2014, 09:19:41 AM »
Thanks sir,,
I am using dr. Pulley 14 gm rollers,,, is it  okay?
Re: please help.
« Reply #3 on: September 28, 2014, 11:46:19 AM »
Is 16 gram the OEM weight?
Did you get slightly more RPM w/ the Dr Pulley? Are they the rollers or Sliders you are using?
If they are the rollers I would go w/ either Malossi purple or red for the spring. If you are over 200 lbs go red.
At or near 200 go w/ the purple.
Ahmad Mustafa
Re: please help.
« Reply #4 on: October 29, 2014, 03:41:16 PM »
The OEM weight is 15.4 gm and yes i got a little higher rpm
I installed both the rollers and the sliders
I am around 180 Lbs
I will  install malossi yellow clutch springs
so what is the best adjuster spring to use?
brand and colour please
thanks
Re: please help.
« Reply #5 on: November 19, 2014, 12:48:59 AM »
Red or Purple Malossi are what I would use.
OR a set of 14 gram sliders, and the yellow or white Malossi.
Sorry for the long delay.
