Author Topic: Speedometer cabel and plug problem  (Read 1342 times)
Adept
  • Empaticus Maximus
« on: September 29, 2014, 02:49:51 PM »
Hi there
My speedometer cabel torn apart at the plug. Can you tell me what kind of plug is this? Can I buy it alone, or just with the whole bunch of other cabel??
(the black cabel is my fixing attempt yet, but it isn't succeed.. .:(( )
Please help...
« Last Edit: September 29, 2014, 02:51:27 PM by Adept »
I have a barely used (200km)14gr Dr Pulley rollers to SELL!! Send a PM if you interested in...
Re: Speedometer cabel and plug problem
« Reply #1 on: September 29, 2014, 04:26:42 PM »
Hi there
Please help...
   at   (powersportswarehouse.com )  I found under F 18 harness wire
part # 31340-lfhi-eoo front wheel speed sensor   $63.07  you got caught with a disc lock didn't you?
best of luck and ride safe  don goulet
Adept
  • Empaticus Maximus
« Reply #2 on: September 30, 2014, 06:25:06 PM »
Yes I have found that, but I need the next section of the wire. From the plug (at the neck of the fork) to the speedometer.
« Reply #3 on: October 01, 2014, 12:57:22 AM »
  by the look of the diagram it is pluged in to the harness # 32100 lea7-m30     $213.60    can you get in to the harness and open it up, and replace the wires, and is the plug in good working order  if the wires are pulled out of the plug they can be repaired, you need a flat blade 1/8 wide and very thin to slide into the plug to remove the wires  elec. shops have the tool for that and replacement connectors  or just change the plug completly
Adept
  • Empaticus Maximus
« Reply #4 on: October 01, 2014, 05:34:20 AM »
I think I saw the plug in the 32100... :D But 213bucks?? Kiddin me??
Okay I try to find the plug in an elec.shop... :
« Reply #5 on: October 01, 2014, 06:21:16 AM »
That price is for the whole wiring harness. I have a few in stock i think they are like $20 I'll check tomorrow and pm you.
