Author Topic: People 250 fuel system problem  (Read 1860 times)
dougm
« on: October 13, 2009, 05:25:33 AM »
I just bought a 2007 People 250 and when I bought it the idle speed was set very high, so I dialed it back down, but now I know why - it stumbles and occasionally dies at idle, and at low rpm's it feels like its running rough. But this only happens when the tank is completely full.  As it drains down the problem slowly gets better until you get to about a half a tank and then it goes away completely.
I was thinking this was a leaky needle valve problem - overflow drips into the venturi and the bike stumbles/stalls, but looking at the carb blowup it appears as though the float bowl is on the bottom of  the carb, which means overflow probably doesn't go into the venturi? (Plus, I think the tank is below the carb?)
Everything else about the bike is perfect - starts instantly, runs fantastic at mid-high rpms, pulls well, etc.
I haven't actually cracked the carb open yet, before I do I'd like to get the thoughts of the experts on what the problem might be and what to look for.
Thank you for your input,
DougM
Re: People 250 fuel system problem
« Reply #1 on: October 14, 2009, 08:39:46 PM »
I'm no expert, but it sounds like it is getting too much fuel. The idle jet has diffusers in the carb. that may be clogged. I would certinly pull it, and give it a THOROUGH cleaning. Sewing needles will help to get into the tiny places that gunk will hide. A spray can of Brake Clean is also VERY handy
jprestonian
    • a scooter called wanda
« Reply #2 on: October 14, 2009, 10:50:19 PM »
Also make sure the intake clamp is tight, and the two vacuum lines (indicated by red dots) are attached and undamaged.
dougm
« Reply #3 on: October 16, 2009, 12:03:25 AM »
Thanks guys, sounds like the best bet is a full carb rebuild.  I'll pull it apart and let you know what I find,
DougM
jprestonian
« Reply #4 on: October 16, 2009, 02:11:07 AM »
Before you do that, you might do what I outlined, first. It might save you a heap of work.
