Author Topic: Engine?  (Read 2401 times)
Copskidjoseph
Engine?
« on: September 29, 2014, 10:48:27 PM »
Is a kymco agility 50 motor a gy6?
The moped learner
Engine?
« Reply #1 on: September 29, 2014, 11:04:14 PM »
Yes
The moped learner
Engine?
« Reply #2 on: September 29, 2014, 11:05:32 PM »
But there is a 150cc gy6 and a 50cc gy6
Re: Engine?
« Reply #3 on: September 30, 2014, 12:10:20 AM »
It's a yes, and no to your question.
It's the exact same engine as the QMB 139 (gy6) EXCEPT the stator, and CDI are different.
I forget for sure but I think the Kymco version has a DC cdi, and stator output to it, and the QMB is an AC version.
(I might have it backwards)
ConradFr
Re: Engine?
« Reply #4 on: September 30, 2014, 10:43:38 AM »
For a 4 stroke 2014 ts a DC CDI with a pickup output to it from the magneto generator (no ac output to it)
Bye
Re: Engine?
« Reply #5 on: October 01, 2014, 10:09:01 PM »
If your thinking of doing a gy6 swap.you will need to swap stator.
Re: Engine?
« Reply #6 on: October 01, 2014, 10:35:39 PM »
 ;)   ;D
Redundant
Re: Engine?
« Reply #7 on: October 03, 2014, 05:51:46 PM »
I recently replaced my Agility 50 engine with a 139qmb ( I blew it up - a long and boring story ), and the only difference in the stator is the a50 uses a 3-wire stator ( white, yellow, blue/yellow ) and the qmb adds a forth red/black wire that goes to the ac/spark on an ac only system. Since the a50 runs the spark off of the battery it doesn't use the red/black wire, but it works if you just connect the other three.
ConradFr
Re: Engine?
« Reply #8 on: October 03, 2014, 06:36:16 PM »
Hi
Why do you not use the AC CDI of the 139 qmb instead of the DC CDI of the Agility ?
Bye
Re: Engine?
« Reply #9 on: October 04, 2014, 12:33:29 AM »
mmmmmmm. I dont know about that.does it charge the battery back up like it should.and does all the lights work.and other elec.things.
Redundant
Re: Engine?
« Reply #10 on: October 05, 2014, 03:28:42 AM »
Yes, although I will likely go with a dc to ac mod, it charges the battery and runs the lights - and my headlight is a 45/40 which I replaced the 35/35 with.
Redundant
Re: Engine?
« Reply #11 on: October 05, 2014, 04:16:01 PM »
Hi
Bye
Hey, yeah, as I said, the Agility works fine with the DC CDI if you don't connect the red/black wire but I went ahead and finished the AC CDI mod.  I just had to replace the black (12v) wire going into the CDI connectors with the red/black wire from the new coil and swap in an AC CDI ( I had a couple on hand from previous scooters ).
I believe that my lights are now brighter...
I also did it in a way that the original connector for the DC CDI is still there, and I could swap it back in if I wanted.
« Last Edit: October 05, 2014, 04:17:51 PM by Redundant »
Re: Engine?
« Reply #12 on: October 06, 2014, 01:49:23 AM »
Good job and smart thinking.wish I did that when I did my swap.I just switched stators.but your way sounds better.good luck and happy rideing.
